Results 1 to 10 of 11
Thread: New member, 2004 Vectra 2.0 Dti
    Feb 2011
    wirral
    Default New member, 2004 Vectra 2.0 Dti
    Hi everyone,
    Bought the car a few days ago, seems to be ok, no unusual knocks or rattles, only thing I've noticed is the dashboard warning light (spanner symbol) comes on now and again for a few minutes and then goes off again for no reason.
    The car still drives ok and doesn't go into 'limp home mode' or anything.
    Will have a look through the forum to see what I can find out.
    Cheers,
    Frank
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    to Vec-c
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    there should be sumfin in hear 4 u!!!
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    welcome ,try cleaning the egr and boost sensor take a look at the how 2
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by frankiebdv View Post
    Hi everyone,
    Cheers,
    Frank
    Does the light show on cold engine start? Check your glow plugs.
    Regular Member leonvectrac's Avatar
    south shields
    Welcome along
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    hi, ive found this site helps alot. hope you do too.
    Feb 2011
    wirral
    Hi, thanks very much for all the replies.
    The light has usually been off when starting up the car and then come on a few minutes later then gone off again or come on before I've started and not gone out straight away. No particular order.
    Not been on any long journeys yet, just 10 mile hops so no idea if it will develop some more issues but will look for a 'how 2' over EGR valve and boost sensor cleaning and hope for the best.
    Also noticed it doesn't always start 1st time, this has happened 3 times now but started on 2nd or 3rd try so not unduly worried unless anyone thinks otherwise.
    Thanks again,
    Frank.
    Feb 2011
    Isle Of Wight
    Hi guys I'm new too, joined after google search for water build up in passenger side footwell!! Stupid VX design flaw under the pollen filter! But lots of info on here and fixed the problem thanks to loads on here!
    I had the same problem with the engine management light and it was the glow plugs needed replacing! Easy enough but heard they can be a b*tch to get out if old! One of the threads went on mine lucky was just enough to fit new ones and they've held and problem solved!
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    I had the same problem with the engine management light and it was the glow plugs needed replacing! Easy enough but heard they can be a b*tch to get out if old! One of the threads went on mine lucky was just enough to fit new ones and they've held and problem solved![/QUOTE]
    I think someone on here says warm the engine first and the glowplugs come out easier but don't burn yourself!!
  1. 2004 Vectra SRi 20r
    By chrisgriffiths in forum Introduce yourself.
    Last Post: 12th June 2012, 12:47
  2. 2004 vectra
    By mickyamyam in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2012, 16:27
  3. My 2004 Vectra LS 2.0 DTI
    By bigdunk1985 in forum Quick Photo Album
    Last Post: 19th August 2011, 21:32
  4. 2004 Vectra 1.8 LS
    By doilum2003 in forum Cars for sale
    Last Post: 27th March 2008, 00:18
  5. 2004 VECTRA 2.2 SRi
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2006, 13:49
