Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Vacuum hose upgrade on 1.9cdti
    Liverpool
    Default Vacuum hose upgrade on 1.9cdti
    Finally decided to fit the samco hose I have had lying about for ages. Changed 2 of the 3 hoses (not the one which disappears under the engine)
    And......
    Now have no hesitation or lag after 1200rpm! Pulls a little smoother and seems to be spoiling turbo up quicker
    Shame I bought 3 meters, only used 30cm lol!
    Next mod, airbox mod part deux!!!! (well just similar to vxr airbox)
    wirral
    Default hi
    hi
    noticed you changed your vac pipes did you change pipe and do away with the elbows??
    where did u get ur pipe i need to do mine
    thanks
    Liverpool
    Yeah just full lengths of pipe
    I have loads of hose left so what I am going to do is cut it up and sell an upgrade kit to do the 2 small hoses
    Will be in the for sale section soon
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    What is the vxr airbox mod Paul ?
    Sep 2009
    Glasgow
    what is the diamater of the tubing, looking to do this mod also
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    Can you post pictures of this..sounds interesting
    north east
    Quote Originally Posted by nokiaman1978 View Post
    4 mm Internal Diamiter ( 4mm ID) on ebay)
    got a 1 meter length that i keep meaning to fit
    Liverpool
    Quote Originally Posted by Aikon58 View Post
    Going to add an additional air hole next to where the airhose enters box
    4mm
    Quote Originally Posted by johnnyboy1985 View Post
    Pics will be up once weather gets better and I finish 2nd box mod when I get 5mins to myself lol!
    PRESTON
    I dont get why this is called an upgrade, surely you are just replacing one vac hose with another. As for it making a car more responsive, i would suggest that the old hose had become porous, as they do, and so not maintaining vacuum. I replaced mine with replacement VX pipes, as the old ones had perished and the car performs great.
    The old ones were as fitted from new and the car has covered 107k
    Regular Member Matt8's Avatar
    Cheshire
    Here here!!
    Not even sure what you mean but sounds like a nice easy make a difference job!!
  1. Vacuum hose over the counter?
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2011, 11:46
  2. Samco 4mm Vacuum hose upgrade for 1.9cdti
    By paul_sri150 in forum Parts for sale
    Last Post: 27th March 2011, 08:13
  3. Vacuum/turbo hose temp's
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 19:16
  4. 1.9cdti Turbo Hose
    By bgm46 in forum Engine & Drivetrain
    Last Post: 17th June 2009, 22:33
vectra cdti turbo upgrade
vectra c 1.9 cdti vacuum hose
https:www.vectra-c.comforumshowthread.php128748-Vacuum-hose-upgrade-on-1-9cdti
vectra c vacuum hose
vectra cdti vacuum pipe
vectra c vacuum pipes
1.9 cdti vacuum pipes
z19dt vacuum pipes
whats the best 4mm vacuum pipe
