Results 1 to 2 of 2
Thread: Egr vavle & spanner light
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    Default Egr vavle & spanner light
    I had both fiat gaskets fitted yesturday along with the egr valve cleaned out but the garage have said the inspection light wouldnt stay off...is there anything i can do or have they done something wrong?
    stockport
    Thumbs down
    Quote Originally Posted by johnnyboy1985 View Post
    Can you check the fault code it's throwing up?.P0400 is the one for insufficient flow,it could be that the gasket is too restrictive for the EGR gasses.Some find that when they semi blank their EGR's the 6mm hole in the gasket isn't enough and they have to open it up till the spanner light doesn't come on at all.By the inspection light,I suppose you mean the EML?,this will come on automatically following on from the spanner light and has to be cancelled with a coder,or will go off after a set number of restarts.It could be that they have run the engine with the spanner light showing and this has then,in turn,activated the EML,(yellow engine symbol). FELIXX.
    By Shadrack in forum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
