Thread: leaking water, driver's floor ?
    Feb 2011
    middlesbrough
    Angry leaking water, driver's floor ?
    need help with a water leak, driver's side floor keeps getting wet, have cheacked the drain for leaves, water coming through somewhere ?
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    have you lifted bonnet, removed rubber strip and poked something throught the drain hole? Its about afoot below windscreen at back of engine compartment under wiper linkage? Really sorry if this is obvious, not being patronising but thought i'd check, just in case. The hole can be blocked with black sludge. My passenger side didnt look blocked until i stuck stick through it.
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    check the pollen filter drain hole !!!
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by wallace78 View Post
    And the one on the drivers side....below the wiper mechanism.. far left.... difficult to see from outside the car....
    Search - Wet Carpets...lots of posts/threads on the subject...
  1. water leaking
    By jinkie in forum Engine & Drivetrain
    Last Post: 14th August 2012, 19:51
  2. Water on floor not blocked scuttle
    By roverjay in forum Bodywork & Interior
    Last Post: 27th May 2012, 22:47
  3. water in boot floor???
    By richiem in forum Bodywork & Interior
    Last Post: 18th November 2011, 11:38
  4. Water leak drivers floor
    By grumpano in forum Vectra C / Signum Troubleshooting
    Last Post: 25th June 2008, 21:07
  5. Leaking water
    By peter142 in forum Engine & Drivetrain
    Last Post: 5th September 2007, 15:10
vectra c leak drivers floor
