Thread: Vectra C 52 Plate Power Steering Problem
    Feb 2011
    Newcastle
    Default Vectra C 52 Plate Power Steering Problem
    Does anyone have any help for me??
    My Vectra power steering has now stopped working, the fluid level is ok and all electrical plugs are connected. It stopped working in July last year, it then used to work every now and then but it has now not worked for about a month. when it did start working it would work for around a week at a time.
    Any help would be appreciated.
    Darlington
    When the steering wheel is turned, can you see current drop IE lights dim out a bit.
    Can you hear the pump whining when you turn the wheel?
    Is the light on the dash illuminated? if do you will need the fault codes read via Tech 2.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Should be a fault code stored ;0 best to get it read as it might be a simple fix or it could be an expensive fix
    Irmscher Insignia CDTI 130
    Feb 2011
    liverpool
    I own a vectra at the moment but am looking at buying another. Its a 1.8i VVT but is being sold at a knockdown price as it has a power steering problem! the seller says it goes hard then works fine any ideas on the worse case scenario? cheers
    Darlington
    Could be pump or fliud problems all sorts of things - TBH if you are in the market for a Vectra, and its not 100% perfect and/or the seller is not going to sort out these problems for you.. then I would walk away there are loads of Vectra's out there
    Its not worth the hassle TBH
  1. 1.9cdti 150bhp 55 plate vectra power steering stopped operating
    By Whiteknight841 in forum Engine & Drivetrain
    Last Post: 13th June 2013, 14:21
  2. 2004 vectra power steering pump problem
    By Yates0721 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th March 2012, 22:49
  3. Power Steering problem
    By delete1 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 20:41
  4. Power Steering problem
    By H11LGX in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2006, 01:19
