Results 1 to 10 of 22
Thread: Cdti Hesitation At 2000 Rpm
    Apr 2006
    PETERBOROUGH
    Default Cdti Hesitation At 2000 Rpm
    I Have Astra 150cdti Sri Running On A Regal Map.been On Astra Sites
    No Help.when Running At Constant Throttle Between 1800 To 2500
    Rpm In Any Gear The Engine Has A Very Slight Misfire Even Changing
    Over To Other Map On Sport Button Makes No Difference.the Engine
    Is Ok At Higher Rpm And Pulls Thru Gears Well With Very Little Smoke.engine Has Done 21000 Miles 10000 On Remap Only Been Playing
    Up For Last 1000 Miles Since Left For 2 Week Holiday. New Filters Oil,fuel.air Filter Kn Cleaned.tried Different Disiel From Bp And Esso. Any Ideas
    Dec 2005
    In the sponge-monkey tent
    Have you spoken to Regal about it?
    Not being a diesel expert, but remebering what others have said before. It may be the injectors, or one of the injectors, failing in the open position?? i.e. allowing too much diesel in at lower RPM so it runs rough, but at the higher RPM's it is running fast enough to burn off the excess fuel.
    Has the car gone back to REGAL??, Whats their take on it?
    Also, have you had the Turbo checked to see if it's boosting correctly??
    Apr 2006
    PETERBOROUGH
    Going To Ring Thorney Motorsport Next Week As He Has Done The Service And Does Warranty Repairs On Vauxhalls.
    Regular Member installer's Avatar
    Nottingham
    I have this problem 1.9 cdtI (150) - (don`t have a map though or box)
    Goes in tomorrow to try and fix at dealers.Always on light/constant throttle between 1600 - 2000 rpm for me.
    Does it most of time.
    Been in before and wouldn`t do it so they re-generated my DPF.
    But getting worse.
    Nov 2005
    Bromsgrove
    Seriosuly, there are many things that can cause issues, ive had a litle agro with 3 people who think that no matter what they do to a car the remap is the cause of any issue.
    In reality, a remap will show any faults allready in the car in a more prominent mannor yet it is unlikely any decent remap will actually casue an issue with your car.
    Regal know what there doing so i wouldnt say there mapping is directly the problem.
    Has it been on a diagnostics?
    East Midlands
    I had exactly the same problem about a month back on my Vectra 1.9CDti (150), took it to my local Vauxhall who said it was a common problem and Vauxhall have issued a Field Remedy which consists of a software upgrade.
    Solved the problem, been perfect since.
    Apr 2006
    PETERBOROUGH
    Thanks For That Hope Its A Patch And Not A As I Will Reboot Loose The Remap Will Speak To Thorneys Today
    Here, there and every where!
    Had this problem for the first time today. Went to Birmingham this morning and it started a slight misfire at around 2500 rpm. Pulled ok, ticked over ok but had this slight judder whilst under very gentle acceleration or on CC at a constant speed
    Trip to the dealers methinks.
    Jan 2006
    Dalriada
    i have this on mine
    The dealership took it back in to look at it and upgrade the software but it made no differnce hence 6 months on its still here!!
  1. Hesitation 2000-2500Rpm
    By Aidi in forum Engine & Drivetrain
    Last Post: 15th February 2012, 21:47
  2. hesitation between 1500-2000 rpm
    By doggydoctor in forum Engine & Drivetrain
    Last Post: 28th July 2011, 10:42
  3. Mis-fire hesitation 1800 -2000 rpm cdti 150
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 29th July 2009, 09:45
vectra c cdti 150 bhp hesitation
vectra c hesitation 2000rpm
