Thread: CDTi 150 oil change
    Regular Member R2XPT's Avatar
    Scotland
    Default CDTi 150 oil change
    Is there a How2 guys? Can't find it anywhere if there is lol
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I've looked for you too Ray,i can't find a how 2,but the oil filter is down the back of the engine bay,and the sump bolt will be underneath the engine
    I've not done mine myself yet mate,as i put it in the dealers for a service when i bought it,so i couldn't tell you what you need to do it
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    Its easy to do an oil change on the cdti 150. Jack the car up, remove the belly pan, remove the sump plug (13mm socket) i would get a new sump plug washer. Refit and tighten the plug once empty and then its onto the filter.
    Oil filter is located at the rear of the engine to the left next to the starter motor (plastic nutted cap can be seen on the picture below, to the right of the flywheel) remove the yellow sleeve on the bottom of the filter and when you loosen the threaded cap the oil will run from this outlet and into your container. Cant remember the exact size of the nut but defo need a 30mm+ socket to remove it. If you are replacing it with a genuine vx filter then once the cap is removed, give it a clean and replace the o ring located at the top of the threads on the plastic cap (new o ring supplied with filter) When refitting push the filter into the filter housing on the engine, give it a good push till it pushes home. Then screw the cap back on, refit the yellow sleeve, refit belly pan, fill with oil and job done!
    If you buy an aftermarket filter you click the filter into the threaded housing first before screwing it back on, hence why i mentioned if your going to use a genuine one.
    Hope that helps.
    Attachment 38349
    Jan 2010
    worcs
    Its easy to do an oil change on a cdti........ take to your nearest national tyres and get them to do it for £38 !!!!
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    where they fill it with 10w-40 semi synthetic and knacker your turbo lol, wouldnt suprise me if they did tbh
    Jan 2010
    stockton on tees
    Thats if they do it all! or happen to forget to change the filter accidently on purpose! lol i wouldnt trust them one bit! do it yourself and you know its done properly!
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by vxpenfold View Post
    10w-40 won't just kill your turbo unless you're driving in -50°C at 5000rpm
    Jan 2010
    worcs
    they done mine for that, using fully syth catrol edge 5w-30
  1. oil change on cdti
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 14:37
  2. Oil Change 1.9 cdti
    By broadgates in forum Engine & Drivetrain
    Last Post: 30th April 2010, 13:12
  3. CDTi Oil Change!
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2010, 20:01
  4. V6 Cdti Oil Change
    By BIG NEIL in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2008, 12:59
  5. 1.9 CDTI 16v OIL CHANGE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 29th January 2008, 14:43
signum cdti 150 engine belly pan site:www.vectra-c.com
signum cdti 150 engine belly pan www.vectra-c.com
