Thread: Rear bumper removal for towbar fitting
    Regular Member Neil71's Avatar
    Oct 2007
    Fraserburgh, Aberdeenshire
    StatsVehicle Info
    Default Rear bumper removal for towbar fitting
    Hi, has anyone any info on how to remove the rear bumper from the insignia so as that I can fit my detatchable towbar and twin electrics.
    Has anyone fitted the twin electrics as I have heard that you have to run a wire along inside to the fuse box at the front.
    Any help greatly appreciated.
    Thanks guys
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    StatsVehicle Info
    Hi..Where did you get yous towbar from..From what ive heard i think the towbar wiring is a bit of a nightmare on the insignia..
    Oct 2007
    StatsVehicle Info
    Hi, I bought my towbar from internet from PF Jones. I paid £268.40 including VAT and also included dedicated wiring and plug in module with the latest 13pin socket. Towbar is Witter.
    The module has GM stamped so it should be straight forward.
    A wire has to be run to the front fuse box beside the glovebox.
    When I bought my car the garage agreed to Tech2 the module (free of charge) to enable the electrics once I had everything fitted myself.
    Regular Member Whoosh's Avatar
    North East
    StatsVehicle Info
    Might be a bit late but found this
    Saloon/Hatchback only - Remove rear light clusters, 2 plastic nuts on each located behind small panel in boot, lift forward edge upwards to release from pegs, disconnect wiring plug.
    Remove bumper, 3 plastic plugs on lower edge, 3 torx screws around perimeter of each wheel arch, 4 on vehicles with mud flaps, disconnect harness for number plate lights (Saloon/Hatchback only) and reversing sensors if fitted.
    Additionally, on Sport-Tourer Estate remove tailgate stops (2 torx screws on each).
    Pull bumper tip outward to release from clips along bumper-body edge, pull bumper rearward to release from clips in the light cluster seating areas and clips across the rear panel.
    Oct 2007
    StatsVehicle Info
    Cheers, thanks for the info.
    I haven't fitted my towbar yet and I am now waiting on my twin exhaust back boxes and twin exhaust insert to arrive then I will get everything fitted at the same time.
    Thanks again.
  1. SRI Rear Bumper with towbar?
    By iani in forum Styling
    Last Post: 28th April 2011, 03:36
  2. OPC Line rear bumber towbar fitting
    By Smove in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2009, 11:23
  3. Towbar For VXR Rear Bumper Help
    Last Post: 17th June 2007, 16:50
vectra c towbar fitting
insignia rear bumper removal
insignia sport tourer dedicated towbar wiring
back bumper vectra c clips
Does the bumper need removed to fit vec c bumper
how.to.remove.rear.bumper.vauxhall.vector.c
how to remove rear bumper vauxhall insignia
how to change rear bumber to vectra
vauxhall insignia rear bumper removal
how to remove insignia rear bumper
vectra c rear bumper removal
removing vauxhall insignia rear bumber
how to remove a rear bumper on vauxhall insignia
