Results 1 to 10 of 15
Thread: Booked in for Monday at RED-DOT
    Regular Member Mopar Man's Avatar
    herts
    Default Booked in for Monday at RED-DOT
    Had to be done as i cant afford to go any further with me Charger
    Well the daily is going on the rolling road first to see what we have to start of with. Then remap with EGR Turned off. Was told 200bhp and 350 ft 1b torque to be had for a sum of £250 cash. We will see
    What will i expect from the wheels before map. All mods done?
    Brought a boost gauge today and think its no good. It only goes up to 20 1bs? Road test and went of the gauge, recon about 30 plus.
    I fitted this in before the remap to see the difference
    Am busy tomorrow with another 150 like mine. 42000 on the clock and the link bar already off and injector leak. Wanted to fit a a fiat EGR gasket, anybody no the part number. Thanks
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    good luck with the remap bud, seems like there is a remapping frenzy going on around this forum at the moment...
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    herts
    Quote Originally Posted by Caveman_nige View Post
    All getting hooked
    Jun 2009
    South Coast
    6 Post(s)
    you should bring that charger along to the rolling road day on the 27th
    herts
    Rolling road, now that would be fun, even just to break it
    Regular Member PORKBALLS29's Avatar
    Epping
    Oh yes please!! You've got to bring it.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    You need a 30psi gauge for your boost as they boost 21 psi as standard mine now boosts 25psi all the way after remap
    Hope this helps
    herts
    Quote Originally Posted by winnie2457 View Post
    Hope this helps
    Thanks mate
    Just found EGR thread
    kings lynn, norfolk
    Hi mopar jut tried to inbox you but it's full here goes the dpf process
    Not a wet one as in it does not use a fuel additive or ha a feed tank is uses active regeneration which when te ecu determines that the do is getting full will Iniate the regen once iniated the egr valve closes then on the exhaust stroke of each piston diesel is injected on the exhaust stroke this diesel then passes through the pre cat which raises the temp up of te gasses and fuel and once it hits the main cat at the front of the dpf heats up even further to about 550 degrees c this then makes the dpf glow red and burns all the soot to ash. This will last about 15mins and engine should not be switch off as it's 20mins of madness te ecu is going through. If this is interuptted the ecu will restate the regen again once car is up to operating temp and will continue until it completes a full regen.
    Hope this helps mate
    herts
    Pugs and vw have a wet feed and a pain in the arse
  1. M.O.T due from monday would you use quickfit ??
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 09:02
  2. Lanzarote Monday
    By mspvxr in forum The 'Off Topic' room
    Last Post: 19th June 2011, 12:18
  3. new car monday !
    By clembo38 in forum Introduce yourself.
    Last Post: 18th April 2010, 19:09
  4. Is it a Friday pm or a Monday am car?
    By kel123 in forum Engine & Drivetrain
    Last Post: 17th July 2008, 10:47
  5. What i did on Monday
    By Johnsdutton in forum General Chat
    Last Post: 24th February 2008, 21:13
