Thread: Ccv & semi blanking for the 120 cdti.
    stockport
    Exclamation Ccv & semi blanking for the 120 cdti.
    I know there is a positive reason for doing these mod's on the 150,but is it viable to attempt it on the 120?. FELIXX.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The fact that most do it to 'protect' the swirl flaps then I would say it's pointless. Good mod none the less for simple manifold cleaniness - but not a must as is made out.
    Gazza4
    stockport
    Talking
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Cheers for that.It was my son that mentioned it,he's got a 120 and wondered if he could gain any advantages from trying it.
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    You will have a cleaner EGR for a long time. And cleaner air in to the engine, so it will be good for the engine. The output will not change, because on full trotle the egr is closed.
    Theoretical the mpg should go down a bit. So why not do it. the 120 works fint with blanking plate with a 6mm hole in.
    ket
  1. 1.9 CDTI 150 EGR Blanking Plate
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 19th February 2012, 23:43
  2. egr blanking on a 3.0 v6 cdti
    By shreky in forum Vectra C / Signum Troubleshooting
    Last Post: 15th July 2011, 15:34
  3. blanking plate cdti
    By rob1981 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 18:16
  4. SEMI BLANKING of EGR and BREATHER/OIL TRAP.
    By felixx in forum Engine & Drivetrain
    Last Post: 4th October 2010, 23:27
  5. Egr semi blanking plate.what size hole?.
    Last Post: 1st October 2010, 00:26
