Results 1 to 3 of 3
Thread: Vectra C 1.9cdti (120) Steering pump
    Nov 2010
    East Midlands
    Trim : design
    Default Vectra C 1.9cdti (120) Steering pump
    Hi, Could anyone tell me if I replace the steering pump from my car with one from a donor car - will it need programming into the ECU even though the old one is not showing a fault, and if so what details would I need for the replacement pump.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by alcutler View Post
    Bump
    Jul 2010
    folkestone
    replacing the pump will throw the steering light on but it will work will need a tech2 session too remove the light if it bothers you, there are 2 types of pump one is on the steering rack itself 05 onwards iirc and the other is under the drivers side headlamp(before 05ish). hope this helps
