View Poll Results: What do you prefer?
Voters
33. You may not vote on this poll
  • Coilovers
    11 33.33%
  • Shocks and Springs
    23 69.70%
Multiple Choice Poll.
Results 1 to 10 of 14
Thread: Coilovers or Shocks & Springs????
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    Default Coilovers or Shocks & Springs????
    After reading LOTS of different theads i cant see that many people using coilovers (is there a reason of have i missed them?) Now i am trying to decide what to do with my vectra as in handling / lowering wise as i know its never going to set the world on fire or be as nimble as a hot hatch but id like more feedback if possible.
    So what would be your choice? Coilovers or Suspension Kit (Bilsteins as thats all id use)
    If you can suggest them also then fire away
    Kev
    spoons
    Guest
    I'd advise you get a good quality damper and spring kit Job done
    I have KW Variant 2 Inox coilovers but they were very expensive and need professionally setting up for high speed stability, Corner weighting and Geometry
    So unless you just want to dabble with the ride height for the way it looks, I'd suggest a good quality damper and spring kit
    Cheshire
    I have just recieved half my Bilstein B12 kit from Europerformance, The slight problem are the Eibach pro's that have arrived are technically correct 10-65-007-02-22 up to 1135kg for my 3.2 GSi which has the front axle rating of 1065kg.
    The threads on here seem to suggest that the lower kit 01-22 up to 1060kg is a better choice.
    I did think about the coilovers but the trolly jack ride that spoon's describes and all the setting up, not to mention the price, made me settle for the B12, which i know will be pretty much as good as it gets with minimal adjustment.
    Jul 2009
    Paul how much was the B12 kit and where from?
    spoons
    Guest
    Quote Originally Posted by paul667 View Post
    I've since raised the ride height on my coilovers and its much better on ride quality now... perfectly acceptable
    Cheshire
    I bought the B12 (B8 shortened dampers) from Europerformance £680 delivered! LMF quoted nearly £100 more.
    I was tempted by the Weitec coilovers with fixed rate dampers.
    Jul 2009
    might have to pop see you and then see what the rides like when fitted to see what to get if you dont mind?
    liverpool
    cheap coilovers for looks and firm ride , expensive coilovers for both looks and ride quality , shocks and springs for slight lowering and decent ride
    Jul 2009
    Quote Originally Posted by lazy_arse_pie View Post
    you have?
    Cheshire
    Quote Originally Posted by Kev_G View Post
    should not be problem!
    The finished ride height concerns me!
  1. coilovers or springs
    By richardcee in forum Handling & Braking
    Last Post: 12th March 2012, 21:49
  2. springs,shocks,coilovers buying 2moro advice needed.
    By Vectra boy in forum Handling & Braking
    Last Post: 20th August 2011, 22:20
  3. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  4. Rear shocks gone? May get coilovers...
    By Torque in forum Handling & Braking
    Last Post: 10th December 2010, 22:21
