Results 1 to 10 of 13
Thread: ...Is this Normal??
    Durham
    Default ...Is this Normal??
    I was driving to work this morning, The temperature was around 75-80 when the car warmed up, it always sits at that.
    I drove fro around 30mins, then going up the carriage way I overtook a craine and many other cars and the temperature was around 90ish or close too.
    When I drove the car normally again, the temperature started to drop, I have never noticed when going faster in the car that the temperature has reached that high before?
    Also, going at a higher speed the car appeared to splutter? Well it appeared it did... I am not 100% on that one, I will have to try it again later.
    Anyone got any tips? or is this the norm.
    Many thanks
    Adam
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Normal mate
    Irmscher Insignia CDTI 130
    Durham
    How come I have never seen the temperature gauge go that high before? - I rekon If i kept booting it like along a motor way stretch the meter would go even higher? - or would it.
    So what may have caused the 'juddering' in the engine, like I say im not 100% it did this, i need to confirm it, but it may have just been a 'one off'
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Not sure on splutter but if I floor it my temp would rise to 90 and then drop slightly
    Durham
    Thanks very much, I knew I could rely on Helpful advice from here.
    I rekon from now on ill continue to drive like a grandad...it sure helps on diesel, cos I noticed that needle drop fast!!
    Ill keep an eye on the splutter and maybe reply on this post.
    Many thanks again.
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    might of been a blip but it's always good to open her up once in a while
    Durham
    I hope it was a blip, im gona check it again this afternoon and come back
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Probably nothing to worry about. Mine has a little hickup every now and then when you boot it and it hesitates for a second. Only really notice it on the motorway in 5th though. Every week or two get it up to temperature then give it a good boot full into high revs a few times to blow all the crap out.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    9 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 210,022
    It is often worth giving the radiator a bit of a clean. Crud and old leaves can accumulate in the fins. I use a soft brush. My Vectra does not increase its temperature, even if I give it a proper bootful.
    Keep an eye on it. Try to figure out exactly when it raises its temperature. It's early days yet but there is a chance that your thermostat is on the blink and not opening fully. That restricts coolant flow. Or your radiator cap may not be sealing effectively, allowing the coolant to boil.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Jul 2009
    The Rift, Cardiff
    I not 100% but I think the fan(s) kick in at 92
  1. Is this normal?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 10th April 2012, 15:10
  2. Normal or Way Out?
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 19:22
  3. is this normal ?
    By bigbranno9 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 10:41
  4. is it normal
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 4th January 2012, 22:24
  5. Is in normal?
    By Pulja in forum Diesel Engine related
    Last Post: 28th June 2011, 20:20
