Thread: Need help with the swirl rod/rail/link/bar
    Regular Member corderz's Avatar
    Bradford
    Default Need help with the swirl rod/rail/link/bar
    Right.....After discovering earlier today that my swirl rod/rail/link/bar (what ever you want to call it) wasnt connected. So gone about to fix it using the good old £1 fix using the tap washers. Tried them for size first, then went about gluing them to sockets which went fine. Now the problem is, i cant get the *bleepers* back on to the joints, how the heck do you do it? there isnt enough space to get in there, is there anything i can take off to give me more room!
    URGENT HELP NEEDED!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The 'fix' is suitable depending on how bad the swirl flap bearings have jammed. If they have been jammed for a long time or generaly really stuck, then the fix won't do much for them if anything.
    Replace the manifold m8. That fix won't last terribly long even if you do manage it, and anyone who says otherwise is telling you what you want to hear imho.
    Gazza4
    Bradford
    they arent jammed at all, can move them round quite easily, a bit of carb cleaner helped moving some crud!
    Just havent got enough space to get them back on
    Bradford
    anyone else help me with a solution to getting them back on
    stockport
    Thumbs up
    Quote Originally Posted by corderz View Post
    Maybe you could try using some long nose pliers or long tweezers/forceps,to place them in position over the rod pegs,then either push them on yourself or get some help. FELIXX.
    Sep 2009
    Glasgow
    easy 2 min job, use a chop stick or similar and a long screw driver, make sure all the connectors are at the same position and on the actual rod you will notice a hole in the middle force the chopstick into it and then place onto pots and puch down with screwdiver to secure, if your lucky you will get a good few miles out of this fix.
    Sep 2009
    Glasgow
    did it work mate.
  1. Swirl Rail Modification......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 9th August 2012, 16:17
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. How can I get here? (Forth Rail brige Q)
    By John LE in forum East Scotland
    Last Post: 12th February 2010, 17:47
  4. Network Rail...
    By Penfold101 in forum General Chat
    Last Post: 15th December 2008, 14:30
  5. which Vec C's have cant rail airbags?
    By freshprince in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2008, 14:02
