Thread: Gear box transmission oil?
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Exclamation Gear box transmission oil?
    HI, What is the best OIL FOR THE GEAR BOX ON MY 1.9 CDTI ELITE 150 6 SPEED DIESEL, I Believe it has an F40 GEAR BOX.
    I also have heard to put in 2.7 litres instead of 3.2, what is the best OIL For the gear box and how much should be put in & where can I get it from & the ring / sump?
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    I used Castrol SMX fully synthetic in my F40 gearbox.. You use 2.4 litres, not 2.7 or 3.2..
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Is this an official VX remedy for the 1st to 2nd sticky change when cold?
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by OPC View Post
    Yes. The earlier cars had 3.2 litres in them, and there's a Vauxhall official fix that involves reducing the oil level by 0.8 litres. The later cars had 2.4 litres put in at the factory.
    S.E
    Quote Originally Posted by Caveman_nige View Post
    Oil: http://www.halfords.com/webapp/wcs/s...egoryId_165750
    Also add in a tube of this:
  1. Transmission Issue??
    By recipro in forum Engine & Drivetrain
    Last Post: 10th September 2012, 02:18
  2. Transmission losses
    By Hideous in forum Diesel Engine related
    Last Post: 16th April 2011, 10:48
  3. Transmission Snatch
    By JDL in forum Engine & Drivetrain
    Last Post: 16th December 2010, 16:02
