Thread: key query
    Jan 2008
    ireland
    Default key query
    was going to buy a key from a veccy c with all the electronics and transponder in it from a 2007 car in a breakers yard,
    i currently only have one key,
    so the plan is..get a new blade and code the key to my car using op-com
    is it possible to do this or do i require codes from the old key also??
    all advice, help and info greatly appreciated
    did a quick search but majority what i found was regarding lots of people wanting a flip key lol
    West London
    as far as ive read on here, the transponders are single use and cannot be reprogrammed once they have been programmed once.
    Jan 2008
    ireland
    so i cant make an old key "learn" a new immobiliser??
    fudge anyway, can i possibly cut the key to at least get the car open??
    Dave
    Quote Originally Posted by unreal_event_horizon View Post
    Correct.
    Yes, but if you unlock the door with the key and then open it the alarm will go off. Only way to silence it is with a working remote or putting the key in the ignition. If the ignition doesn't recognise the key transponder (which in this case it won't) then the alarm will continue to sound.
    Regular Member i5aces's Avatar
    andover
    there was a thread recently about removing the transponder and soldering in a new onr the blank transopnders are only about a fiver.
    its just how good you can solder without damaging the transponder with the heat.
    i am going to try this im just waiting to find a cheap flip key to try it with
  1. H.i.d kit query??
    By Marcosuk in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 20:07
  2. GSI query?
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2011, 10:38
  3. BSR Query
    By Jezzy in forum Petrol Engine related
    Last Post: 26th January 2010, 17:35
  4. Tow bar query
    By Agoogy in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2009, 08:52
  5. GM Oil query
    By SCOTTEX in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2006, 11:43
