Results 1 to 10 of 15
Thread: flickering headlights??
    Sep 2010
    england
    13 Post(s)
    Default flickering headlights??
    was sat on my drive this morning and noticed the headlights was flickering.
    im parked within a couple of feet of a wall and could clearly see the lights flickering around the outside of the beam and also flickering brightness??
    is this normal??
    or suspecting battery/alternator??
    car is 07 CDTI elite estate WITHOUT xenons
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by dog View Post
    is this normal??
    yes its normal, if you rev it they should stop flickering, tick over is not enough charge to do the job, mines been doing it for years, so have a lot of lads on here.
    Liss
    Vehicle : Astra (J) Sports Tourer
    Trim : SE
    Engine : 2.0CDTi 165bhp (S/S)
    is this normal??
    Yep my 08 SRi Estate does it at low revs. You just get used to it!!
    Regular Member scottyd's Avatar
    paisley
    could be overcharging. Get it checked.
    Sep 2010
    my 08 SRI CDTI hatch has never done it.
    Regular Member YT07's Avatar
    south cumbria
    my 07 cdti 120 does it as well,had everything checked out when aux belt tensioner was being fitted at stealers and nothing was showing bad anywhere.
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    my 05 elite does it also!!
    WGAF#5
    the flickering is generally noticable when your turning the steering wheel whilst stationary as the electronic PAS system takes massive amounts of load/power to run - this makes it noticable ... as others have said once revs are higher and the car is moving you have additional current generation and it doesnt happen .... if you had the older radio display on the car you could also see this flicker at the same time as the headlights
    HTH
    Dez
    Dec 2010
    belfast
    Regular Member Bobarache's Avatar
    Perth, Australia
    is this normal??
    This might be a different fault but I had the same on my 3.2V6 but I also noticed it got worse over time and the car wasn't idling great in gear with the brake on - was a really simple fix - just had to clean out the inlet manifold butterfly valve with some carby cleaner....I think there is a "how to" on this site.
    Has never done it since
  1. Flickering headlights
    By Mrpam in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2013, 23:12
  2. Flickering Headlights
    By erni3wi5e in forum Bodywork & Interior
    Last Post: 9th March 2012, 16:57
  3. Headlights flickering ???
    By digitalinkjetman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2011, 11:49
  4. Headlights flickering
    By troutybrown in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2011, 19:46
  5. Flickering Headlights
    By exclusive07 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2007, 20:39
