Thread: Suspected Crank Pulley Oil Leak
    May 2007
    Question Suspected Crank Pulley Oil Leak
    I have an 04 plate Vectra 2.2 Design Auto (45k miles) which has recently developed a small oil leak marking my drive. My local small garage had a look and the mechanic says he thinks it's leaking at the crank pulley oil seal. This is something he's not able to deal with.
    Can anyone advise whether this is a 'big' job or not ? Does it need a main dealer or can a 'higher-end' local dealer do it ? Any idea on a likely cost for the job ?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi E
    any decent garage that do engine repairs can easily fit a new seal to timing case,it requires supporting engine with mounting removed and lowering engine about 20/30mm and lifting vehicle slightly.
    the seal is not expensive your main expence will be labour cost,shop around and get a couple of quotes.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    is that a diesel or petrol as my 2.2dti is leaking too and i was wondering if it was a big job
    Jul 2009
    Engine : 20 Dti
    Diesel peadar
    Aug 2007
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    does the timing chain cover have to come off or just the bottom pully
    May 2007
    Default Suspected Crank Pulley Oil Leak
    Apologies, I should have been more clear, my 04 plate 2.2 Vectra C Design Auto is Petrol not Diesel.
    jonnybravo : is your description of the job still valid for a 2.2 Petrol engine ?
    Jul 2009
    Engine : 20 Dti
    Yes Englishman,different engine obviously but similar job.
    and no peadar seal is levered out after removing pulley,engine has to be lowered slightly to gain access to seal.then new seal pressed in
  1. 2.0DTi Crank Pulley !!
    By Led in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 17:55
  2. Crank Shaft Pulley???
    By Stephen S in forum Engine & Drivetrain
    Last Post: 1st September 2010, 20:27
  3. Crank Pulley Damper
    By KevinC in forum Engine & Drivetrain
    Last Post: 11th January 2008, 20:15
  4. crank pulley
    By andyc#elite in forum General Chat
    Last Post: 18th November 2007, 09:12
opel 2.2 dti 2001 oil leak
vauxhall vectra oil leak
oil leak on vauxhall vectra 2.2 diesel
vectra c oil leak pulley
vectra 2.2 oil leak at pulley
vauxhall vectra 2.2 diesel crankshaft pulley
opel vectra 2.2 dti oil leak near wp
vectra 2.2 diesel crank pulley
small oil leak on my 04 plate vectra
vauxhall corsa behind pully oil leak
vectra c 2.2 oil leak
