Thread: flashing spanner and wont start
    Regular Member jofenan's Avatar
    nottingham
    Default flashing spanner and wont start
    earlier tonight i tried to restart my cdti 150 after a few minutes (nipped into a shop) and all i got was all the usual lights on but nothing...no clicks from relay or dimming of lights....had a flashing spanner symbol too.....tried it about 10 times and then it started like nothing had gone wrong...my trip home takes me down the m1 and it did a pdf clean as usual (mine does it every couple of days)...is this a common occurrence and is there anyway i can read the fault code?
    Jan 2008
    ipswich
    my do that when i get to about half tank it clean out the smell is horrible
    11 Post(s)
    Quote Originally Posted by jofenan View Post
    That's telling you there was an immobiliser fault.
    Car didn't recognise the transponder inside the key.
    As for fault codes, have you tried the pedal trick - look in the how2 section for more info.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    A garaged diagnosed mine (without reading fault codes) as an immobiliser fault and suggested to me it was a job for an auto electrician. When he came he plugged in his thingy and it actually turned out to be the crank shaft sensor.
    nottingham
    if it didnt recognise the transponder could the remote just need a new battery?
    11 Post(s)
    No, the battery is only used for the remote central locking.
    The car will still start with no battery inside the fob.
    nottingham
    its not done it since so hoping its just a one off!..have found 3 possible ways of reading the fault codes,so will give them a go later
    Regular Member Innes's Avatar
    Plymouth
    I thought the imobiliser warning was a padlock through car icon?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    if car didn't start because of immobilizer fault it would be a padlock symbol
    Irmscher Insignia CDTI 130
    11 Post(s)
    Padlock for older Vectras. Car/spanner light for newer ones. I don't know the changeover dates.
    My 2006 Vectra flashes the car/spanner light if there is an immobliser fault.
    My previous 2004 Vectra had the padlock symbol.
    Also documented in the handbook.
  1. Flashing Spanner
    By Knight Rider in forum Engine & Drivetrain
    Last Post: 6th September 2012, 17:36
  2. Replies: 23
    Last Post: 31st August 2012, 11:52
  3. flashing car and spanner light
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 16:32
  4. Spanner on dash wont start please help
    By alshel in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2009, 02:25
  5. flashing spanner light
    By carp in forum Engine & Drivetrain
    Last Post: 27th April 2006, 14:53
vauxhall astra immobiliser car wont start
vauxhall astra wont start immobiliser
vauxhall spanner light flashing
2008 cdti astra wont start
zafira wont start spanner light flashing
vectra c flashing spanner
https:www.vectra-c.comforumshowthread.php128573-flashing-spanner-and-wont-start
zafira wont start immobiliser
vauxhall zafira wont start immobiliser
vectra c wont start engine light flashingvectra c 3.0cdti car wirh spanner light flashing and wont turn overvectra c padlock symbol spanner warning light and vectra wont startvectra c spanner warning light car wont start flashing spanner light and wont start vectra cdtispanner light flashing on vectravauxhall zafira 2004 flashing car with spanner lightholden vectra car with spanner flashingvectra wont start spanner light flashingMy vauxhall insigna will not start dashboard flashes and pings astra wont start key flashingvectra car with spanner warning lightvectra c spanner light on wont turn overastra car with spanner dashboard light turns over but wont start
