Thread: Headlights flickering constantly also engine misfire,any advice?
    Regular Member v33tra's Avatar
    ayrshire,scotland
    Default Headlights flickering constantly also engine misfire,any advice?
    I`ve got a couple of problems with one of my vec c`s so i`m looking for advice / possible solutions
    firstly the car is a
    2007 vectra c 1.9 cdti 120
    the problem is my headlights constantly flicker when the engine is revved up and when driving infact all the lights flicker i.e dashboard lights,headlights etc and it`s really really annoying
    another issue i have and i don`t know if it`s related to this fault is a definate misfire at low revs ( below 2000 rpm ) when driving in town etc it is quite noticable and usually requires to be dropped a gear to be more driveable and to stop it feeling jerky to drive
    i connected a multi meter to my battery today while the engine was running ( tickover speed ) and have noted the alternator doesn`t send a steady constant voltage to the battery when charging it constantly flickers between 13.80 volts and 14.30 volts changing between the two every half second or so which has lead me to think the alternator doing this flickering output is causing my lights etc to flicker also ???
    any advice / thoughts on this would be most welcome
    p.s the alternator was changed for a recon unit after the original packed in about a year ago before this change the lights were ok and also after it was changed only recently has the flickering fault occured
    do you think the new alternator is now faulty?
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by v33tra View Post
    Sounds very much like the alternator regulator is on the way out causing the slight surge in power that is changing the intensity of the lights - go back to who ever replaced/supplied it and ask for a replacement.
    ayrshire,scotland
    thanks but it`s out of warranty ( was only 3 months )
    11 Post(s)
    How long have you had the car?
    Thinking along the lines of The Sale of Goods Act.
    http://www.which.co.uk/consumer-righ...t/your-rights/
    Six months...and counting
    If your claim is about a problem that arises within six months of buying the product, it's up to the retailer to prove that the goods were fit for purpose – or 'as described' – when it sold them. It is also responsible for proving that the problem was caused by you (for example, because you had an accident with the item that damaged it). Beyond six months, it's up to you to prove that the problem was the retailer's.
    So you may need to prove that the fault was not down to wear and tear or damage you caused, and that the product (or a component) should have lasted longer than it did. To do this you may need an expert's report, for example from an engineer or mechanic.
  1. Flickering headlights
    By Mrpam in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2013, 23:12
  2. Flickering Headlights
    By erni3wi5e in forum Bodywork & Interior
    Last Post: 9th March 2012, 16:57
  3. Headlights flickering ???
    By digitalinkjetman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2011, 11:49
  4. Headlights flickering
    By troutybrown in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2011, 19:46
  5. Flickering Headlights
    By exclusive07 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2007, 20:39
1.9 cdti miss fire and low batterry voltage
vectra c headlights flickering
vectra c lights flickering
astra 1.9 cdti flickering headlight
headlight flicker misfire
