Thread: 2.2 DTi Turbo Hose...£142.80??!!
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Default 2.2 DTi Turbo Hose...£142.80??!!
    Hi all,
    Managed to finally get the bonnet open today, and was able to investigate the hissing noise that appeared while the Turbo was on boost. I found the split hose after working out where all the oil was coming from.
    I took the hose, (pictures attached), to a local VX Dealership and they said it only comes complete with the bottom section, total cost inc VAT of £142.80!
    I was hoping to just replace the hose, so any recommendations where to get one from, either like for like, or upgrade.
    Many thanks in advance,
    Chris
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    ebay sells one
    EDIT: This
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    i saw on here the other day think it was Innes made the pipe on the other side from silicone hose and a metal elbow in the middle sure it said it cost bout £30 couldnt this b done for the one you need? just nan idea i dont really know.
    Regular Member Mr Hyde's Avatar
    Feb 2011
    Suffolk
    Had 2 hoses go that way on an old MG ZT tdi. Was expensive too........ Hope you get one cheaper mate.
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    Danwells72: I literally just found that same listing! Thank you for your help!
    dansri: If thats the one I'm thinking of, its the other hose. Looking at mine, I don't think I need to replace that one.....yet!
    Mr Hyde: I never realised how expensive they are. To be fair, this is the first engine related fault I've had in nearly 5 years!
    Chris
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by chrisschild View Post
    Chris
    No probs mate, you can however get a pipe (i think from ash) for about £40 which is a flexi reinforced silicone hose. ill have a look as i get their magazines due to the amount i spend there lol
    EDIT: This, its blue but if you go to their shop they have black and red
    Regular Member Innes's Avatar
    Plymouth
    Everyone beat me to it! Yeah Vauxhall take the piis because they know thatthese two hoses fail on the 2.0 and 2.2dti's. They go from the inside out because the oil vapour from the turbo is slighlty corrosive to the cheap rubber Vauxhall used. As they go from the insideout you wont know its gonna go until you get the hissing!
    I replaced the one you have circled from the guy on ebay for £60. 2 weeks later the other hose went so I decided to make my own instead of forking out another £60.
    My thread is here.
    http://www.vectra-c.com/forum/showthread.php?t=116528
    I havent seen those flexi hoses Danwells has posted up. They could be worth a try. A bit cheaper too! You'd need a bigger inner diameter than 38mm though. I think the size is 52mm but I would get a tape measure out and double check the size of BOTH ends before ordering.
    Jul 2006
    Northampton
    Trim : Sri
    im pretty sure it was 1.5" when i measured it when doing the intercooler upgrade. All my pipework is bespoke so i dont really need any of this but i have kept the left side pipe. Considering this one and one for the MAF to turbo pipe
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    Just a quick update, I ordered the £60 hose, it arrived, I've fitted it and the car now drives so well again! Thanks for the advice you guys! :-)
  1. Turbo hose kit. Cheap???
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2012, 23:12
  2. turbo or split hose??
    By jsnlvxr in forum Engine & Drivetrain
    Last Post: 8th November 2010, 17:54
  3. 2.0 dti turbo hose
    By dervb in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 14:15
  4. 1.9cdti Turbo Hose
    By bgm46 in forum Engine & Drivetrain
    Last Post: 17th June 2009, 22:33
  5. 2.0 DTI Turbo hose
    By cp123 in forum Engine & Drivetrain
    Last Post: 7th March 2007, 19:12
vectra C 2.2 tdi turbo
vectra 2.2 dti turbo pipe
2.2 dti turbo
