Thread: Engine Management Light
    Essex
    Default Engine Management Light
    Should the Engine Management Light extinguish under self test when you turn the ignition on. Or should it only extinguish when the engine starts?
    Regular Member dax's Avatar
    Anglesey
    It should turn off when you start the engine...........if it stays on RUN,ROLL,DUCK AND COVER
    Essex
    Thanks. Iv heard that if its on when the ignition is there are fault codes stored on the system. If there is no history of codes the light will extinguish under self test,
    5 Post(s)
    Quote Originally Posted by rocket999 View Post
    Correct.
    Essex
    Thanks Big Dave. Does this mean I need the ignition on when I plug the fault finder machine in? I had the engine running last time and no faults were found even though the light was on when the ignition was and didn't go out until start up.
    5 Post(s)
    What do the instructions of your code reader say to do?
    As the fault code is only historical and not current, it'll self delete after a number of clean start ups or 'x' number of days.
    You only really need to start worrying when the light stays on with the engine running.
    Essex
    The EML comes on when I get stuck in heavy slow moving traffic, usually takes about 15 mins of slow traffic before it comes on and then a few mins later the car cuts out and it takes a minute or two before i can re-start it. It all then happens again unless I start driving in normal conditions. Once I park the car up over night the EML wont come on unless I get in slow moving traffic again. Awful.
    Anglesey
    Ok well EML's want banning, I came to my car this morning after work and started her up, the same "sounds like a bag of s**t* for the first 2 minutes then driving it is very unresponsive sometimes, then other times its fine and drives almost perfectley but when i am driving you can feel her being sluggish/judderry but only slight judders in the acceleration,this happen through out all gear changes as i accelerate,then some times i accellertate and she is like s**t off a shovel, anyways too the point...........i drive 2 miles down the road and the frakkin light turns off and has not come back on since, i.m like OMG its been on perm for 2 weeks +, yes i am being dramatic dammed car its like a love-hate affair.
    Anyways so i took it too the local garage(the local i,m gonna take all your money for nothing merchant) and he infact.............wait for it...........was very helpful......... I described to him the symptons and he straight away said "Fuel Filter" £15 supply £10 to fit £25 in total. not bad I think.
    So i,m gonna try that on Monday and see if it solves my problem.
    Regular Member rob1964bike's Avatar
    Elgin Scotland
    Yep effin hate EML mines is on so I changed fuel filter and still on going into limp home mode when I hit 3,000 revs ****ing me right off it is it runs perfect until I go over 2,500 revs getting it checked on Wed hope nowt big may just need reset after new fuel filter.
    3.0 V6 Diesel
    By Shadrack in forum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
