Results 1 to 2 of 2
Thread: Front brake imbalance
    Chelmsford
    Default Front brake imbalance
    Got an advisory for the above on the MOT last week.
    Discs are pretty new, so fairly sure they're not warped. Pads don't have too many miles on their either.
    What's the best way to service the calipers?
    the imbalance means one side is braking better that the other
    one of the most common problems for this is that the sliders and rubber grommets they run through get all dirty
    when you remove the caliper you undo the sliders ( 7mm allen key )
    once youve taken the caliper off the best thing to do is remove the sliders ( they just pull out and then remove the rubber grommet they run through ( just pulls out)
    clean both bits up and the replace the rubber grommet
    once the grommet is bak in place properly put a small amount of oil or copper grease on the slider and slide in back into the grommet and you will notice it will slide very freely
    viola job done
  2. New front brake kit
    By Rob12 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 21:29
  3. Front Brake Help Please
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 16:59
  4. VXR Front Brake Kit
    By spoons in forum Parts for sale
    Last Post: 17th March 2009, 13:53
  5. new front brake discs?
    By kev bux in forum Handling & Braking
    Last Post: 19th October 2007, 19:33
vectra c front brakes imbalanced
