Thread: Alarm
    Angus Scotland
    Default Alarm
    Hi i have just replaced the battery on my vectra a few days ago as i thought it was goosed i have tried to start car yesterday and the new battery is flat i have tested the alternator and it is puting out 14.4 v and the battery once charged is holding 12.96 volts i have noticed the red led light on the alarm button flashes right from the start insteadof being solid the n flash according to the vectra manual there is a problem with a sensor i have put it on a snap on scanner and there are no code faults any ideas where are the door and boot sensors i have tested the connection and switch for the bonnet already and that is ok , could a dodgy alternator diode cause this
    Angus Scotland
    ok last night i manually shut the car doors and never set the alarm when i went out this morning the battery was exactly the same voltage as left last night so it is the alarm system that is draining the battery does anyone have any ideas of where to start to find out what part is causing the problem my car is a hatchback
    Admin plasma's Avatar
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    There are two parts to the alarm, the siren unit in the left hand side cubbyhole as you open the boot and the ECU part of it where the BCM ecu is which can be seen once the glove box is removed, I would advise to disconnect the siren first and see if this is the cause of the drain.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Angus Scotland
    hi would this also cause the switch to flash right away rather than once armed properly , also can a tech 2 scanner find out the problem there is one on a auction website i was going to buy ? when i was checking the fuses the siren unit seemed to work ok once activated ?
    Angus Scotland
    hi i have removed the siren in the boot but the alarm light still activates and flashes right away rather than waiting for approx 10 sec then flashing any other ideas where are all the sensors that activate the alarm so i can check them out
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    There's a bonnet switch this is located by top drivers strut
    Sorry just read you have checked this switch
    I had same problem with led flashing quickly, Turned out to be ultrasonics once I changed them the fault went
    Irmscher Insignia CDTI 130
    Angus Scotland
    Default ultrasonics
    is that the one about the gearstick below the mirror can this be removed for testing
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    It's by interior light mate by the rear mirror, I would check connectors and make sure it's plugged it correctly then try and set alarm to see if the fault has gone
    Angus Scotland
    Default alarm
    ive disconnected totally and no difference ive a new one comming to see if that makes a difference
    Angus Scotland
    fitted a new sensor but still the switch led still flashes all the time indicating a fault andf ideas ive just freed off the boot switch as it was seized what else can i check ?
  1. Car alarm keeps going off
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2015, 18:37
  2. Alarm keeps going off?!
    By Ben Chiles in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2012, 22:26
  3. Alarm led?
    By Vectra Karl in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2012, 22:43
  4. alarm keeps going off
    By the fisherman in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2011, 01:22
  5. how do i get to my alarm??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 19:51
