Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: 3.0CDTI V6 1500rpm engine judder - Facelift??
    Doncaster
    Default 3.0CDTI V6 1500rpm engine judder - Facelift??
    Hi
    I've done lots of searching on the forum for problems with the V6 3.0CDTI engine and the engine judderring/shuddering at 1500 revs in 4th, 5th & 6th gears, as I'm having this problem with my engine.
    I have a 08 reg facelift (z30??) and all the threads talk about a pre-facelift (y30??) engine having this and possible probs with the SCV valves???
    Can this still be the issue with the facelifts and the Z engine???
    Cars been into dealer to have a look at it - and he says no fault found.....
    Any help would be appreaciated before I go back to them..
    Many thanks
    Richard
    Full Member Big Sig's Avatar
    Yes it can still be an issue but its less likely to be so. It could also be an injector issue.
    get them to put it on a tech 2 and look at the actual fuel delivered compared to the fuel demand. That (iirc) is one of the ways to check for the SCV fault.
    Doncaster
    thanks for the reply big sig!
    Also, forgot to mention!, MPG has gone right down - loosing about 50 miles per tank. Is this anything to do with it???
    Hmmmm, don't know. The car isn't doing a dpf regen is it?
    Quote Originally Posted by doncaster_mainline View Post
    Typical dealership, they look for the "easy fix" and simply look for fault codes
    On the Y30DT a blocked SCV could not be diagnosed from the EMS, as this had not been taken into account
    The EMS would only return a fault when the input fuel had dropped below 50%, in effect this only happened when the SCV was completely blocked and this eventually happened on mine
    The repair fix includes an update for this on the EMS
    VX advised this could not happen on the Z30DT, as the issue had arisen and the updated EMS was already in place along with the uprated SCV
    Saying all that is fine, but was it actually done?
    From the numbers of people with Z30DT engines that are now reporting these same symptoms it would appear not, and I am not really surprised
    Take the car back, report the issue is erratic with dropping revs and power, the difference in performance feeling like the brakes are being applied
    Is there an increase in smoke from the exhaust, especially in 6th gear at 70mph?
    At constant speed of 50mph in 5th gear, does the turbo continually switch on/off/on/off/on/off? (If unsure, put the drivers window down and listen)
    When does your warranty expire?
    How many services, and records for the fuel filter being replaced?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Replace the fuel filter.
    Quote Originally Posted by Celes View Post
    Need to find out how old it is first, no point replacing one that is under 12 months / 10K miles old
    Mine was caused by the cambelt, or part of the cam timing system. It vanished after it was changed...
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    On my old 3.0 it got clogged up after just 3months/3k miles...
    Oct 2009
    Bilbao&Madrid
    Trim : Cosmo
    Engine : 3.0 CDTI Z30DT
    Well, if it helps, this is my account of the blocked SCVs saga on a '06 Z30DT:
    http://www.vectra-c.com/forum/showthread.php?t=121839
    It seems you need to go to the dealer with the EML light on and some code stored, or they won't acknowledge there is a problem at all.
  1. Engine judder
    By Mike1975 in forum Engine & Drivetrain
    Last Post: 20th September 2012, 14:52
  2. Engine judder
    By pipamish in forum Engine & Drivetrain
    Last Post: 24th March 2012, 18:24
  3. Low Rev engine judder.
    By super sleuth in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 19:56
  4. How to remove engine cover - facelift 3.0CDTi
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2009, 20:47
  5. cdti 150 engine power below 1500rpm
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2008, 14:15
flat spot at 1500 rpm vectra 3.0cdti
vectra c cdti v6 juddering
vectra c 3.0 cdti air control solenoid
vectra 3.0 cdti shake when accelerating
vauxhall vectra 3.0cdti shaking when boosting
