Thread: Cim Module
    Dec 2010
    wigan
    Default Cim Module
    My car 1.8ls vectra c 52 reg has a probelm with the clocks. Every now and again the battery light abs light handbrake light comes on and fuel guage rev counter and speedo stops working. Steering wheel controls still work wipers still work and horn still works. When i turn it on and off sometimes it all goes back to normal or clocks dont work for a bit. When they stop working the only thing that does work on clocks is the engine managemant when you first start it then it goes out as normal but just nothing else works. The engine management light never fails to work during all this could it be the cim. I have checked and cleaned abs plug checked fuses and checked for lose wires behind clocks.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    If the CIM has had a fault, a code will be stored. Dealer can check for stored codes.
    Dec 2010
    wigan
    can i take it to any diagnostic man or does it have to be vauxhall thanks
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Quote Originally Posted by wiganrl View Post
    You can take it to anyone who has the right kit. VX use 'Tech 2', but maybe others on here who have other kit which would work can advise you.
    I used the VX dealer for my CIM problem as the car was under Network Q warranty.
    Dec 2010
    wigan
    thanks
  1. Can someone tell me where the BCM module is?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 16:41
  2. cim module anyone
    By triplecrown31 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2012, 22:54
  3. CIM module
    By rayvo-gsi in forum Electrical & ICE (including SatNav)
    Last Post: 22nd September 2007, 02:12
vectra c 1.8 ls cim fault
2005 vectra 1.9 cdti bcm and cim fault
vectra c 1.9 sri unplug horn and wipers dont work
cim module opel vectra c
