Thread: Vectra Sri 2.2
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Question Vectra Sri 2.2
    After testdriving a couple of 150 CDti's and reading the common faults like DMF and DPF and Swirl valves I am kind of put off them, so been out today and looked at an 06 2.2 sri which has 65k on the clock, upon asking about the timming chain was shown proof that it had been changed due to a problem with a tensioner less than a year ago.
    What other faults do the 2.2 suffer from as apart from timming chains going due to lack of oil changes I have hard of little else..
    Sep 2010
    More than the CDTi in my experience. They have a common fault of the high pressure fuel pump and at around £600 a fix it's not cheap - things to look out for are:
    fuel pump
    coil pack
    suspension
    wiper assembly
    some common to all models however I had around £3000 of repair bills for my 2.2i over 18 months,... 26 month of a CDTi and largest repair bill has been £85 for upper front shock mount bearings.
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    cheers for that
    Sep 2010
    lovely smooth ride tho - don't think it is as pokey as the 150 CDTi either, averaged 36mpg in the 2.2i against 53mpg in the CDTi
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    I agree less poke than a 150 cdti but very nice ride and doing average of 37mpg
    Sep 2010
    I also found thr front end more responsive and poised being a lighter petrol engine. I still prefer my CDTI tho!!!
    suffered many faults with it in my 18 months
    3 fuel pumps
    2 coil packs
    suspension (shocks) all round
    banana bars replaced
    heater stop working
    wiper assembly fell apart
    heater vents snapped
    as mentioned - some common faults could happy on any engine or model -
    Have you looked at the 2.0T?.. consensus seems to be that this is the most reliable engine
    Regular Member chrisf70's Avatar
    Mar 2007
    Cambridgeshire
    This ties in with the thread I've just posted. Weight of Signum must dent those mpg figures, as weekly at the moment I'm averaging 29.5 in my 2.2 Direct (5 speed) and over the 3 years of ownership it is showing 32.4 as the average mpg.
    Only major fault was the car dying in the first year of ownership but that was the fuel pump which was replaced under NQ warranty.
    So if I take your Vectra 1.9cdti av mpg figures and knock 5mpg off I should get around 48-49mpg av from a Signum with that engine.
    Sep 2010
    those were computer figures quoted - I'd get between 350 and 400 to a tank on the 2.2 and am getting 650 to 700 to a tank on the CDTi
    Mar 2007
    Cambridgeshire
    Hm, so were mine. Car is always serviced and seems to have no noticeable faults. Think I just put the 29.5 av down to stop/start commute during week and then brisk motorway driving at weekends!
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
correct readings for coil pack vectra c 2.2 sri
