Results 1 to 10 of 11
Thread: Think i have found my problem, HELP!
    Regular Member corderz's Avatar
    Bradford
    Default Think i have found my problem, HELP!
    Just been looking under the bonet, i am no mechanic but im sure this isnt right........is it fooooked?
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    looks fine to me mate, its when the bar completely detaches from the lugs and on its side, then its fooked
    Regular Member badback's Avatar
    Runcorn
    Get someone to rev your car mate, and see if it's doing what it should.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    They look gunked up so some carbon cleaner could be used to help them move a bit better.
    Can you lift the bar up? Mine was just laying there feeling sorry for itself and could be picked up but your seems to look ok apart from the gunk seeping out around the plastic inserts
    Bradford
    the right 2 plugs are attached but the left 2 arent, what is this bar and what does it do?
    Jan 2010
    stockton on tees
    Quote Originally Posted by corderz View Post
    If 2 are off then it is fooked, the bar controls the swirl flaps in the manifold, it causes some of the exhaust gases to spin when entering the pots, giving low down grunt! I did notice the difference when i refitted mine which was feeling sorry for itself! I used the £1 tap washer repair 'how2' and mine hasnt fell off since, i did the repair around 4000 miles ago and still spot on! Worth thinking about to get a little longer out of it
    Bradford
    I have been trying to solve the problem of having no grunt about the car, tried everything else. You think repairing this would do the trick?
    Jan 2010
    stockton on tees
    if its just lacking low down grunt then reparing it would make a difference, i drove mine for the first year with the bar off, not knowing what it did, after repairing it and refitting i noticed a big difference on the low down torque, when pulling away from lights etc check your 2 small vacuum hoses for splits on the elbows, clean your boost sensor and for peace of mind give your EGR valve a clean, your car should then run spot on..
    Runcorn
    My swirl rod has been lying on it's side for over 30,000 miles and the car runs fine, slightly lumpy idle when cold but otherwise no problems, I think it depends on how the car is driven, I take mine for a 100 mile run at least once a week and I don't have to sit in traffic queues very often. I'm waiting to have a new one fitted, only because I've decided to keep the car and have the cash (fortunately) to get it done. The manifold itself isn't that expensive, about £160.00 but it's a big job changing it, about 6 hours. Plus I'm having the timing belt and water pump replaced, so it becomes quite pricey. Here's a pic of the new one waiting to go on. hth.
    Bradford
    just had another looks, its not connected at all. If i pop them back on will it be ok?
  1. Clunking when changing gear - Problem found
    By ghostrider in forum Vectra C / Signum Troubleshooting
    Last Post: 16th April 2012, 14:21
  2. Problem part found - Need help identifying
    By skivandal in forum Engine & Drivetrain
    Last Post: 8th October 2011, 20:48
  3. Misted windows - found the problem!
    By andreitone in forum Bodywork & Interior
    Last Post: 14th December 2010, 15:17
  4. Smoking Gun... sorry, diesel problem found
    By blues n twos in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2010, 18:25
  5. Found out what the problem was.....
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 9th April 2009, 16:32
