Results 1 to 10 of 11
Thread: Signum ride very harsh, what to do?
    Sep 2010
    Sutton, Surrey
    Default Signum ride very harsh, what to do?
    Need some advice
    I have a 2007 3.0 CDTI Signum Auto Elite and I am finding the ride very harsh, what is the best thing to do?
    The car is running on 18" XP2 multi spoke as an original option fitted with 225/45 18 tyres.
    Should I change the wheels to the standard Elite 17" wheel with 215/55 17 tyres, will this make the ride more comfortable. this will also give the same rolling radius?
    Or would I need to change the suspension?
    Paul
    Wales
    How many miles mate and has the ride felt harsh since the day you owned it? If its got worse over time, I wodul suspect the suspension is on its way out.
    I though the elite was the 'soft floaty one!'
    Sep 2010
    unless the previous owner modified it,..
    Jul 2009
    Brighton
    I would change your wheels, that way I could have them. The XP2 wheels are nice.
    Are the tyre pressures correct? Too high and they would make it harsh (but improve the mpg).
    WGAF#5
    all above are relavent and points to check
    i'm running elite spec suspension on my 2.8 and its got 17's the ride is lovely and soft - there must be an underlying issue - have you broken a coil spring ?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    had to change mine cos it was toooooooooo soft and wollowy ...
    you wanna buy them lol ...
    When spec'd with the 18" or 19" wheels the Elite got the sports suspension setup which is probably the reason...
    Sep 2010
    Sutton, Surrey
    Think you are right about the suspension, think I will just have to live with it.
    Thanks everyone for your input
    Paul
    Regular Member parttimer1's Avatar
    Dec 2010
    edinburgh
    Aye, my 3.2 elite has the sports susp pack and is much firmer. I prefer it that way though and I soon learnt to avoid the speed bump routes.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Check your dampers they normally only have a life time expectation of 30-40000 miles .
  1. Harsh ride
    By Ziggy in forum Suspension, Wheels & Brakes
    Last Post: 3rd April 2012, 19:56
  2. Harsh ride!!! Can i bear anymore than 17" wheels!?
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2011, 11:49
  3. Harsh Ride
    By fattony in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2010, 22:13
  4. Harsh ride quality with Falken 912s??
    By marky2027 in forum Handling & Braking
    Last Post: 28th December 2008, 15:57
  5. Slightly Harsh Ride from the rear end.....
    By signum_1.9 in forum Suspension, Wheels & Brakes
    Last Post: 13th September 2008, 13:18
