Thread: headlight washer hose
    Regular Member i5aces's Avatar
    andover
    Default headlight washer hose
    just wandering if someone could give me the dimentions and spec of the hose requried fro the headlight wash system.
    i know its ID 8mm is there a maximum OD, and how flexible does it need to be, also what is the longest single length required.
    the reason im asking is im looking to get some through "the system"
    i have found one for me to try and have demanded it the specs are
    HOSE ASSY,NONMET,FUEL/OIL,HYDROCARBON MEDIA;6000MM WORKING LG;RD CROSS-SECT SHAPE;8MM ID,10MM OD;PLAIN INNER CONVEYING TUBE
    when / if i find some that fits and works i am happy to demand some in a share it out to forum members (should save those who want to add the mod a few quid)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Outside diameter much larger than the propper stuff (as I have used) probably wouldn't fit into the clips that hold it along the front bumper.
    I will take OD measurement for you after.
    The longest run (although i've not measured it) would be from the bottom corner of the bumper grill (passenger side) round and up to the driver's side washer jet
    Pictures
    Hope that helps you
    andover
    well i have demanded the hose so will have a go when it arrives and post up the results. if it is to fat and wont fit in the clips couldnt it be cable tied in place
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yeah, you would just have to cable tie it to the foglight wiring
  1. Washer jet hose location + small how-to
    By Damo77 in forum Styling
    Last Post: 12th March 2012, 02:42
  2. Washer jet Hose
    By Dazzy2006 in forum Bodywork & Interior
    Last Post: 28th December 2010, 21:38
  3. 8mtr Silverline washer hose
    By Lump in forum General items for sale
    Last Post: 29th March 2009, 16:30
  4. Headlight Washer
    By Padster72 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2008, 17:54
