Thread: Urgent help needed
    Sep 2010
    SOUTH WALES
    Default Urgent help needed
    can anyone help please? i have a 2007 vectra 2.2 auto sri direct. last week it started playing up and was very flat up to about 2500 - 3000 rpm. when i put my foot down it would seem to clear and pick up a bit but would then play up again and power would deminish again.
    parked it up for a few hours then it wouldnt start at all. plenty of life in the battery (until i run it flat) but it would not fire up. had to then have it towed to local garage.
    mechanic has told me that the oil was so thick that it would need to be drained and engine flushed as it had probuably clogged up everything. done this but still the same. he has done a compression test and it is showing about 50 psi in each cylinder. apparently it should be about 160.
    does anyone have any ideas about what i can try next please??
    sorry to post such a long thread but wanted to make sure i covered all the details.
    Regular Member foyboy241177's Avatar
    May 2008
    eastbourne
    worked at vauxall 5years its fuel preasure regulator fault get them to cheak build date on reg there is a fault with them causing cars to cut out take to vauxhall main dealer if reg at fault its a free repair as warrenty will cover till 2012
    Sep 2010
    SOUTH WALES
    thanks for that. will try that later today. cheers
    Wales, UK
    Let us know what happens!
    Sep 2010
    SOUTH WALES
    i will yeh. they seem to think that i may have a bent valve
    Sep 2010
    SOUTH WALES
    turns out my timing chain has become slack and has jumped a few teeth throwing the timing way out. thankfully tho, nothing damaged, but still £500 to fix.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Topcat4500 View Post
    That seems a bit expensive just to sort the timing out. Are they doing anything else?
    Sep 2010
    SOUTH WALES
    i dont think so. apparantly there is a fault with hydraulic tensoiners which has got to be sorted. any idea what sort of price i should be paying? i aint got a clue to be honest
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Yes the 2.2 does have a tensioner fault which is quite common. I'd try speaking to a couple of independent garages and tell them you need the timing sorting, new chain and tensioner. Explain what's happened and VX have said no damage has been done. I used to frequent a Corsa forum and a lot of people had chains done on the 1.0 engine sometimes with tensioners. Average price was about £300 but very few people used a VX garage because they were so expensive.
    Sep 2010
    SOUTH WALES
    finally got my car back. new timing chains, tensioners, gaskets, timing kits, oil and filter. £776. ouch. best price i could find.
  1. urgent help needed.
    By adierolfe in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 09:53
  2. URGENT help needed
    By vectraedition100 in forum Engine & Drivetrain
    Last Post: 27th February 2012, 20:21
  3. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  4. urgent help needed >>>>>>
    By justin79 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2011, 20:02
