Results 1 to 2 of 2
Thread: Astra question
    South London
    Default Astra question
    Apologies for an Astra questrion on the Vectra forum.
    My daughters Astra has an internal coolant leak,possibly due to either a head gasket leak or cylinder head fault.
    The car runs perfectly apart from topping up the coolant every couple of hundred miles and white smoke/steam from the exhaust.
    If presented for an MOT would this cause a failure due to emissions.
    I have had a "sniff test" done at two different places, it failed at one and passed at the other. I have done my own block test and the test fluid changed from blue to green whereas the instructions for the kit said a failure is indicated by the fluid turning yellow. This leaves me rather confused.
    I would appreciate your opinions.
    Engine : 1.9 CDTi
    It will more than likely fail for high hydro carbons due to not fully buring the fuel correctly.
  1. astra question
    By DAVIDD88 in forum General Motoring Chat
    Last Post: 10th February 2012, 23:31
  2. An Astra Question
    By Tadpole in forum The 'Off Topic' room
    Last Post: 14th September 2011, 21:03
  3. Astra m3 egr question
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2011, 20:04
  4. An Astra question
    By MLC in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2008, 01:38
  5. Astra VXR Question
    Last Post: 19th May 2007, 14:21
