Thread: engine problem or exhaust?
    Regular Member dancam70's Avatar
    Feb 2007
    glasgow
    Default engine problem or exhaust?
    hello hope someone can help.
    have a 150 cdti 2008 plate runs brilliant then every now and then car sounds noisey and mpg goes through the roof done to 19mpg on moterway when usually 40mpg and smell slight burning from exhaust and exhaust sounds noisey.
    and usally when usually when sitting still it says 0.01 mpg on the computer it also goes up to 1.16 mpg anyone any ideas is it a exhaust block or engine fault?
    thanks in advance
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    i maybe wrong but its a regen were its over fueling the engine to burn the crap/soot out the DPF (its on the zorst like a cat) and thats why you have silly readings on the computer
    i maybe wrong as some cars dont have a DPF id say it was tho......someone will tell you if im wrong
    PRESTON
    if your car is an auto dancam, then she will have a dpf. what you are experiecing is a normal regen, they usually take about 20 mins to complete. Nothing wrong with the car at all.
    Feb 2007
    glasgow
    when does this happen every month? i got it about 3 times in a week is that right and my car is a not a auto/
    thanks for the quick replys
    PRESTON
    Hmmm???? normally dpf's are fitted to Veccy estates and auto's, also all Signum cdti's have them too. First you need to determine if she has a dpf, but even so 3 times in a week is alot, mine does a regen every 700 to 1000 miles, but she does alot of slow cold runs, which tend to fill the soot trap faster. If the car is used alot on the motorways, normally the regen period is extended. If she has a dpf and does regen, DO NOT TURN THE ENGINE OFF till the regen has completed. There is a way to tell if you have a dpf, its a code on the drivers side door B post, look at the little black plate, if it has 0.50 in a little square, then your car has a dpf.
    Sep 2010
    in a box
    that funny that i dont know what that is it do sound like a regen tho but cant be has your flexi gone that would smoke but dont think it will change the computer tho
    Sep 2010
    in a box
    Quote Originally Posted by barney490 View Post
    if thats gone look under car and look were the cat would be thats were the DPF is got 2 black pipes on it and a sensor
  1. Possible exhaust problem?
    By Matt_NI in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2012, 22:21
  2. Exhaust problem
    By markj23 in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2010, 20:50
  3. exhaust soot problem?
    By big rich in forum Detailing and Car Care Discussion
    Last Post: 18th February 2010, 23:22
  4. Problem with exhaust system
    By mujju313 in forum Engine & Drivetrain
    Last Post: 1st April 2009, 21:23
