Results 1 to 4 of 4
Thread: Isuzu ideas???
    Dec 2007
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Isuzu ideas???
    I have a kick about corsa 1.7d, its just the plain old isuzu none turbo, no oil cooler as i can see, its running great! temp is fine, no running problems, oil is ok on the dipstick, no mayo under the oil filler cap, But it has started to get a black oil deposit in the header tank, coating the sides & a thin layer floating on the coolant witch is still clean & blue!, it may or may not be the head/head gasket, but the water pump also runs & is mounted on the side of the head!, ideas ??.
    Full Member
    Jun 2007
    N/A
    7 Post(s)
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Water pump 'possibly' or the head. Sniff test needed.
    Gazza4
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Do they have oil coolers fitted to them?
    Are you getting air bubbles in the header tank when the engine is running?
    Dec 2007
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Nothing!, it runs sweet I'm actually using it every day still, it has no symptoms other than the oily residue in the tank, it doesn't even appear to be emulsifying, I haven't seen or cant see an oil cooler but thought it would be the cause, The other thought was the water pump as it does run directly from the side of the head. I think!.
  1. corsa isuzu 1.7d
    By the-wizard in forum The 'Off Topic' room
    Last Post: 21st November 2010, 22:24
  2. Is the 3.2 V6 the same as in the isuzu trooper?
    By Ziggy in forum Petrol Engine related
    Last Post: 14th April 2010, 16:28
  3. Saab or Isuzu?
    By splund in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2008, 22:56
  4. Irmscher Isuzu
    By david173 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 5th October 2006, 03:36
