Thread: Cruise control fuse
    Sunderland
    Default Cruise control fuse
    Hi Guys where is the CC fuse, i have the stalk fitted tried the clutch pedal spring etc... i dont get any light when i turn the IGN on so thought start easy and check the fuses first
    Nottinghamshire
    The cruise control light doesn't come on when you turn on the ignition, only when you turn the cruise control on with the buttons on the left stalk.
    I think you may have to press the brake pedal once after starting the engine before the cruise control will work.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    As James said the engine has to be running, the car has to have had either the clutch or brake pedal pressed and I think you have to be going over 20mph for it to work
    Sunderland
    cheers guys still no go, but i have the fault light on so maybe linked
    It is the brake pedal that is required
    I normally set off having pressed the brake, however when I forget I can often get several miles without having to have touched the brake pedal, but with plenty of gear changes (using the clutch)
    This has caught me out a few times, pressing the cruise control on as I reach the M73 and the speed starts to fall below 40mph...
    Equally, got the M74 once and then switched it on, then again noticed the speed starting to fall
    Ironically, need to touch the brake pedal in order to activate the cruise control
    Nottinghamshire
    One question - why have you come to found that the cruise control may not work? Is the car new to you or have you been doing something to it?
    Knowing the reason may help to identify the problem if we haven't already done so in the posts above.
    One other thought is that the cruise control buttons on the stalk can be a bit dodgy so make sure you press them firmly. My 'set' button (top front) doesn't work occasionally, and I just have to keep pressing it until it does.
    Looks like MARKPRIOR bought this car last week and so was not aware that it was necessary to press the brake pedal
    Therefore might have been sitting looking for the light coming on as part of the pre-ignition check, or as I find driving for a short distance and it has still not been activated
    Nottinghamshire
    Hope so - the free and quick fixes are always the best.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I can confirm brakes only need to be used before you are able to use CC along with over 20mph.
    Sunderland
    yeah just got the car last week, tried again this morning and nothing
  1. Cruise control
    By sizzlechest in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2012, 18:35
  2. Cruise control on ice?
    By se4 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2010, 22:11
  3. control unit steering column module fuse burning out !!! Please help
    By fedehernan in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 21:37
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise control
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2007, 17:19
vectra c cruise control fuse location
ver is cruise fuse on vauxhall vectra 2007
https:www.vectra-c.comforumshowthread.php128438-Cruise-control-fuse
zekering cruise control opel vectracruise control fuse location on vectra cvectra c 2006 cruise control fuse08 vectra what fues for cruise controlfuse for cruise control vectra cvauxhall vectra cruise control fusevectra cruise control fusecruse control fuse for vectra 2005cruise control fuse vectra cdtifuse for cruise control vauxlhall vectra corsa c sri cruise control fusehow does cruise control work on 2008 vauxhall vectra
