Results 1 to 10 of 21
Thread: Signum (07) V6 CDTI front brakes
    Regular Member SRI-150's Avatar
    Jun 2007
    Cheshire
    Default Signum (07) V6 CDTI front brakes
    Car has just failed MOT on front brakes; disks and pads, where's the best place to buy them? I take it they're the 314mm disks aren't they.
    Cheapest price I can find is £95 on ebay
    Yes they should be. I believe VX do a "kit" which contains both disks and pads cheaper than that but the parts dept often don't know they exist and insist you need to buy them separately at a lot more cost.
    I think the part number is in the part number section but I'm sure someone will post it up if not.
    last check was 72 squid plus VAT for the kit...
    Regular Member Jezzy's Avatar
    S.E
    93186299 is the part number I have written down, not sure if it's still valid or been replaced by a newer one.
    Yes, coming in at about £90 incl VAT now
    Add about £70 for fitting
    What did they fail on?
    I could understand it if the pads or discs failed, but not both
    If it is simply the brake efficiency, then get the discs measured, the pads die when they are about 80% worn, but you can easily get three sets of pads to one set of discs
    Jun 2007
    Cheshire
    It's failed on:
    'Service breake imbalance on steered axle'
    An they said the fix is new disks and pads, they wanted £305 fitted!
    Apparently ur allowed an imbalance of 25% these were 36%.
    Jun 2007
    Cheshire
    I changed the pads on my old vectra but can't remember whether u need the brake rewind tool on the fronts or back I'm pretty sure it's the back isn't it
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Autovaux.co.uk will sort you out.
    Regular Member BIG-G's Avatar
    Oct 2009
    thurso
    it's just the rears you need the rewind tool for
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    ****** hell! Where is that from, I was only 60 quid about 3 months ago for mine
  1. Facelift vs Prefacelift are the front Brakes the same on the CDTI?
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 10th August 2012, 15:34
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. Vectra-C / Signum CDTI Front Brake Calipers (OSF & NSF)
    Last Post: 18th November 2009, 18:22
  4. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
