Thread: 2.0 turbo vectra low idle maybe misfire??????
    Regular Member vectra100turbo's Avatar
    manchester
    Default 2.0 turbo vectra low idle maybe misfire??????
    hi, just bought vectra edition 100 with 2.0 turbo engine.
    now it has rough idle and can feel vibration in car,
    emissions light came on, had it read and came back misfire and lambda sensor was advised change 1 of the coils as was probably a week spark as it goes if you rev it above 750rpm does not affect performance etc so i changed 1 coil and have noticed a differance in idle but did not cure it (difference now is doesnt try to cut out) does anyone have any suggestions please
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    probably worth changing the spark plugs as well unless you know for sure when they were done etc.. unscrew the lambda sensors and clean them with brake/clutch cleaner, the first lambda sensor if on the top bend of the downpipe which is bolted to the righthand side of your turbo.. The second lambda is found after the cat and somewhere near or after the flexi join of the downpipe to the mid exhaust section..
    I would recommend cleaning you MAF sensor as well if you do all of the above.. Change your air filter and do the airbox mod.. Run some redex or similiar through the tank and treat it to some decent petrol..
    Let us know how you get on... As you do not really know how is has been maintained/treated before now you may as well assume they did sod all.. I never hurts to give it decent service like this, after all you do want it to last..
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Regular Member Jezzy's Avatar
    S.E
    Sound advice from Nige, plus also change the fuel filter and the other three ignition coils.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    When I got my 2T the emissions light was on. It wasnt after I sprayed carb cleaner through the intake pipe.
    Id follow the advice as given.At least youd know your starting from a good basis.
    And ENJOY!!
    manchester
    thanks i have already done the plugs will try the sensors first does anyone know where i can get coils cheaper than £118 each can i buy the ones for the saab version of this engine the ones in it are saab ones cheers
    S.E
    Find a Vauxhall dealer near you that gives "Trade Club" discounts, and ask what the TC price would be. If the discount is considerable (and it often is), then become a full member on here for £20 and you'll qualify for TC.
  1. vectra c 2litre turbo idle problem and engine cut out HELP
    By davedave in forum Engine & Drivetrain
    Last Post: 8th September 2012, 20:59
  2. Misfire at idle
    By mechman458 in forum Engine & Drivetrain
    Last Post: 12th March 2012, 14:13
  3. Vectra C 1.8 SRi Misfire when idle? HELP PLEASE?
    By shaine415 in forum Engine & Drivetrain
    Last Post: 25th February 2012, 15:52
  4. misfire at idle
    By billroy in forum Engine & Drivetrain
    Last Post: 14th November 2010, 01:11
  5. Misfire - even at idle when hot
    By muctm in forum Engine & Drivetrain
    Last Post: 13th June 2008, 12:07
vectra turbo irratic idle
