Thread: gearbox plugs
    Regular Member i5aces's Avatar
    andover
    Default gearbox plugs
    just wandering if someone could help, i have put my car in the garage for an oil change and the filterhousing has broken so i have had to leave the car there, while its in i asked them to change the gearbox oil and to only put 2.4 liters in as its crunchy between first and second. i did see a thread that had screen shots of TIS and the field remedy about this but cant find it anymore, could someone point me in the right direction.
    also i rang them yesterday to ask them to fit new filler and drain plugs in the gearbox and he said "well we wouldnt normall do, the old ones will be fine" i asked them to replace them anyway with genuine VX ones and their replay was "well ok beut they will probly be exspensive"
    so please could someone post up the price's and/or part numbers so i can check and make sure their not ripping me off.
    its not my local garage as i was at my mums in preston at the time. so their 200 miles away and i dont really trust them after breaking the oil filter housing.
    cheers as always
    cant give you the part numbers but according to a how 2 on this site there about £2 each
    Regular Member Jezzy's Avatar
    S.E
    Part number: 11099271, £2.32+VAT each. Tell the garage you know they're talking BS about being able to reuse the old drain plug, as it states in TIS that the original one mustn't be reused as it doesn't have a washer.
    BTW - this is all assuming that you have the F40 transmission.
    andover
    cheers mate, yes i have the f40
    i read the how to and was going to do it myself but thought as its stuck there i may as well let them do it. at least now i can double check what they have done and what there charging me for.
    cheers again
  1. f23 gearbox oil plugs
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2012, 22:20
  2. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 18th August 2011, 18:12
