Thread: gear stick vibrates in 3rd only ??
    Regular Member tosh23's Avatar
    HULL
    Default gear stick vibrates in 3rd only ??
    Hi my vectra chums, I have a vectra 2.2 elegance dti (2004) 112,000 miles working as a taxi...Great bulletproof car but one slightly annoying problem, all the gears are super smooth but when in 3rd gear the gear stick vibrates and make a small vibrating noise in a very quiet car. If I leave my hand on the gear knob the noise disappears altho the vibration ( now vastly reduced ) is still under my hand..Any ideas ??
    Thankyou Tosh.......
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    not done one tosh but i belive vx fit plastic balancing discs to shift lever,the clearence has to be measured and the discs fitted to suite the required clearence
    HULL
    So it looks like a trip to the main stealer's, My mechanic is very good but as you say its specialised...
    Ive got my mechanic to change the gearbox oil, apparently it only had 0.5 litre's in it...So he has put in 1.9 litre's in...
    Also over the last few weeks.. 3rd gear ( when the car is warned up) is a problem to get in,
    At first looking on here it looked like g/b oil
    I was thinking of very old hydraulic fluid in the system so im going to completely replace the clutch hydraulic oil.
    After that Ive run out of ideas..............Many thanks for your reply......Tosh
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    There I'd a plastic ball joint with a piece around wich cracks thats the problem as it wares my ok dti did it got a new one sorted
    HULL
    Sorry Paul, Do you mean there is a plastic shroud that cracks that is inside the leather cover that hides the selector mechanism around the gear lever ?
    By the way. thanks for the reply mate.....Tosh
  1. vxr gear stick
    By 130786howe in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2012, 18:21
  2. Gear stick
    By Puffalo bill in forum Bodywork & Interior
    Last Post: 4th January 2012, 18:34
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
  5. Help with gear stick
    By wayne10244 in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 21:04
