Results 1 to 2 of 2
Thread: Knocking Sound after installing Anti Roll Bar Links
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Exclamation Knocking Sound after installing Anti Roll Bar Links
    I had a knocking sound coming from the front when the car was driven from cold in the mornings, I took the car to the mechanic's & he told me it was my anti link roll bars, I changed that & since then their is another noise coming from the front drivers side its like clunk sound sound it just happens does not matter what the road surface is smooth or bumpy, it tends not to happen often but you can hear it happen every mile or so when your driving slowly it comes & goes its only started since I had the anti link roll bars put in, not only that the car has had its wheel alignment done & its still pulling to the right, I was told my tread was eaten from the inside i changed the tyres around and this one has hairs around the edges and its still the same, the guy at the mechanics told me swap em around the tyres
    I am letting you know the story so maybe you can build an accurate conclusion on what it could be?
    Many Thanks
    Elahi
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    grease up the arb bushes and drop links and track rod ends. that should help. i had same problem after fitting new suspension all round with lowering springs and new drop links and track rod ends. hth.
    paz
  1. How to change anti-roll bar links and bushes?
    By Jay-C in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2017, 01:36
  2. Anti-roll bar links - easy to fit?
    By MadOnVaux! in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2012, 16:47
  3. Anti roll links or anti roll bushers
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2010, 18:46
  4. Anti Roll Bar Links - Signum
    By arkhan78 in forum Suspension, Wheels & Brakes
    Last Post: 27th November 2009, 10:07
after install bar knocking sound
vauxhall vectra c anti roll bar links
