Results 1 to 10 of 14
Thread: Diesel bleeding
    milton keynes
    Default Diesel bleeding
    Right guys whats the best and easiest way to get the diesel up from the tank to the filter and keep it there, need to get it up there to get it started it a 2.0 dti vec
    Cheers guys
    Nov 2010
    Vectra land
    fill the fuel filter housing with diesel and start the car, hold some revs on untill the fuel from the tank reaches the filter housing. have you identified the cause for the diesel draining back?
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    I've used a improvised pump which sucks it up to the filter. I connected it to the filter outlet to the engine, turn on the pump when it splutters out its there.... Or you could fill the diesel filter full of diesel and start the engine and hopefully by the time it gets near the bottom of it it would have had time to suck the diesel up maybe?
    Regular Member ptrehearn152's Avatar
    norfolk
    take top off fuel filter, fill with diesel, undo injector nuts at injectors, turn engine over til diesel spits out of pipes, tighten injector nuts and start engine
    north east
    or the way the manual says ... the 2.0 is self bleeding, Insert key in ignition, turn to position 2, return ot 0 and remove key, repeat twice, on third attempt start car, If car fails to start repeat sequence again.
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    dti have no fuel pump in the tank whereas the cdti's do.. therefore the above statement would be false in this case
    north east
    Odd those were the instructions in my 2.0 dti astra G owners manual, maybe vauxhall got it wrong but it never failed me when i changed the fuel filters yearly over 100 000 miles.
    Im probably wrong but its shouldnt matter where the pump is if the system is sealed it will suck / pull the fuel untill it recieved fuel .. sucking / pulling the air out of the system ??
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    The only way a dti can suck fuel up in constant cranking (pump located on the engine itself), whilst this is happening and the fuel is slowly being drawn up the diesel pump is running dry! a sure way to kill the pump if done too often. A cdti will prime the system by forcing diesel up to the filter housing and blowing the air back down to the tank
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    spot on Plasma,fill filter ,crack injector pipes,crank ,rest crank rest untill fuel leaks of tighten injector pipes and away you go
    milton keynes
    Didnt realise you to crack of all 4 union nuts at engine I just tried each one, the bloke that had a look at the car was a doughnut an pull the in pipe off the filter ....
  1. Bleeding the air from the diesel fuel system
    By pete7175 in forum Engine & Drivetrain
    Last Post: 27th July 2016, 07:24
  2. bleeding bleeding and adjustment
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2011, 11:29
  3. Need Info on Bleeding diesel pump
    By Pjuk in forum Engine & Drivetrain
    Last Post: 26th February 2011, 17:16
  4. Diesel bleeding
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 25th September 2009, 19:31
  5. Bleeding diesel engine
    By bigbenny4gf in forum Vectra C / Signum Troubleshooting
    Last Post: 17th September 2009, 07:53
bleed injector pipes vectra c
how to bleed injectors on a vauxhall astra 13 cdti
