Results 1 to 3 of 3
Thread: When I Fit My H.I.D`s
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default When I Fit My H.I.D`s
    When I Fit My H.I.D`s..Will I Have To Get My Headlights Set-Up Again Or Will They Be Ok ?
    Just Had Them Set-Up
    Regular Member i5aces's Avatar
    andover
    they should be fine as your not really moving any of the parts just replacing the bulbs, the light unit will bolt back into the same place (if you remove it)
    if you want to double check park facing a wall turn on the lights and mork the cut off point, fit the hids without moving the car then retest they should be the same
    Aug 2010
    Dundee-Motherwell
    True Cool Cheers M8
