Thread: vectra c
    Wakefield
    confused vectra c
    hi all, just purchased a 2.2 diesel vectra c on an 03 plate, ive just sorted my heating problem out, and just realised i av another problem, the central locking works fine with my key fob but the boot wont open with the fob its just making a beeping sound inside the car but can open it with the key as anyone got any ideas ????? and also it beeps wen i use the switch inside the car ??
    Regular Member benny's Avatar
    Feb 2006
    dudley
    silly question are you pushing the button on the rear in when you try it or just turning the key ? ..
    Regular Member Innes's Avatar
    Plymouth
    The beeb is just saying that the boot is ready to open. It wont actually release the latch. You have to go to the boot and prees the boot latch and open it. The boot locks after certain time (30 secs I think) so even if the car is unlocked with the engine running the boot will remain locked until either the boot button is pressed on the fob or on the door controls.
    I forget about it sometimes so when I drop the wife off at work and she runs around to the boot she cant open it. She taps on the window to tell me to press the boot button. As soon as I press it I hear the beep and the wife presses the latch and opens the boot. Its to stop people nicking stuff out of your boot at traffic lights I guess.
    Plymouth
    Oh and welcome to the 2.2dti club :-) Not a bad engine and pretty easy to work on when things go wrong.
    The two common things you may find go wrong in the engine bay are Vacuum pipe rubbers cracking which can easily and cheaply be replaced with silicone ones (See my thread here http://www.vectra-c.com/forum/showthread.php?t=115759 ) and also the inter cooler hoses are prone to splitting due to vauxhall using crap materials. They can be replaced with silicone ones from ebay for £60 each off ebay or make your own like I did for about £20-30. See my thread about it here http://www.vectra-c.com/forum/showthread.php?t=116528
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
