Thread: help please
    Full Member daddyjay's Avatar
    Jan 2010
    poole
    Vehicle : vectra facelift
    Trim : sri
    Engine : z20net 2oltr turbo
    Year : 57
    Mileage : 38200
    Default help please
    Help needed .changed thermostat sunday as was not working so did what needed to do and it worked yip pee but today the needle does not move and dont seem to have any pressure when taking the cap off any ideas . i have 1.9 cdti sri 120 thanks folks...
    PRESTON
    Check the wiring is secure on the temp sender attached to the stat. Does it loose water and how far did you let the car run to get her warm?
    Jan 2010
    poole
    Trim : sri
    Year : 57
    Mileage : 38200
    not looseing water and ran it for about 30 mins at lunch time
    PRESTON
    If the heater is getting warm then i suggest a good run down the motorway, just to see if she reaches temp and, if there are any airlocks it may clear those. Usually if the system isnt pressuring it would indicate a leak, but if water levels not dropping, it cant be that. The only other thing to consider is if the new stat is faulty, it does happen, and if you got it from a dealer and it is faulty, they will change it under parts and accessories warranty, with no cost to you.
    Jan 2010
    poole
    Trim : sri
    Year : 57
    Mileage : 38200
    thanks mate will go give it a run and see what happens
    thak
