Results 1 to 10 of 11
Thread: might have to change the fuel pump.. ok to use the old cambelt?
    Jan 2010
    worcs
    Default might have to change the fuel pump.. ok to use the old cambelt?
    Hi all,
    i ve got a leak from my fuel pump on the back of the engine, the pump is driven by the cambelt.
    i took it to the dealer and they said they might have to take the pump off if they cant locate the leak.
    will it be ok to reuse the same cambelt or should i ask them to fit a new one?
    car is on 54000 miles now.
    cdti 150 engine.
    apparently a new pump costs in the region of 1600 p[ounds fitted? would this include the price of a new cambelt anyway or not?
    only had the car 2 weeks and its turning into a money pit!!....... just as well its under warranty
    cheers
    steve
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Cambelt kit is usually around 200, has it been done yet as to be honest around 60k I would have that and the waterpump done. I had an oil leak on the camshaft I think it was at 25k and they strongly advised me to change it than use the old one. Plus not sure how true this is and where everything is located if anything like oil or something leaking was to go on the belt and cause it to slip... wouldnt be too good.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Never ever refit a cambelt. VX dealer did it on a Vectra B 2.0 I had once and it ended up costing them £3500 to put a never engine in 3 weeks later!
    Although VX say change the cambelt at 100k I would and have changed the cambelt at 60k. Its not always the cambelt that would break but the tensioners as happened to my current Vectra 1.9CDTi under warranty on 59k, another £4000 cost to VX
    Full Member Big Sig's Avatar
    No, change it. Not worth the risk. Maybe if it had only done a few hundred but not 54k.
    Jan 2010
    worcs
    ok then do you think i should be paying for the camblet parts because i wouldnt be in this situation if the fuel pump wasnt leaking .
    the fuel pump is being repalced under warranty.
    should the dealer i got the car from stump up for the cambelt kit?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Well, it's your choice whether to replace the belt, so probably not - but, like the others, if it was coming off anyway, I'd change it.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If the dealer has to take off the Cambelt then they have to fit a new one. VX dealer should know that and not try and make you pay for it.
    Ask them is it common practice to not replace the belt if its removed. If they reply yes then take the car to another dealer.
    Madness not to fit a new belt and like I say if the dealer takes it off dealer pays for a new kit
    http://www.vectra-c.com/forum/showthread.php?t=121315
    The belt does not have to be taken off to remove the fuel pump nor does the cam timing etc. need to be disturbed. Have a look at the how to above and all will become clear.
    Jan 2010
    worcs
    its a tricky situation though as i got the car from a car supermarket in derby, im now down in abingdon with the RAF as my job and the local vx dealers are doing the work and the car cupermarket are paying for it over the phone.
    the techy who came out to look over the car seemed to think that as the car has only done 54 thou the camblet should be ok?
    Jan 2010
    worcs
    thanks for pointing that out to me mate, hopefully vauxhall will be aware of that so they dont have to take the belt off!!
  1. Y30DT Cambelt / Water pump change
    By dshelton999 in forum Engine & Drivetrain
    Last Post: 23rd February 2013, 23:13
  2. Cambelt and water pump change
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 1st August 2011, 14:39
  3. Cambelt kit & water pump change
    By Pete1nlancs in forum Engine & Drivetrain
    Last Post: 30th July 2010, 19:07
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
