Results 1 to 3 of 3
Thread: trailer indicator tell tale light. yes or no?
    Regular Member brotherkennyh's Avatar
    Swadlincote
    Default trailer indicator tell tale light. yes or no?
    I realise this is already ont he forum, but I am asking again because I am not satisfied that what I have read is conclusive.
    I have just had a towbar fitted to my 2.0L DTI. It's an 04 reg.
    I asked for the dedicated wiring to be fitted.
    I get the impression that it is a legal requirement to have some way to tell if the trailer indicator lights are working and that this is usually a buzzer or dash board light. In the case of the vectra the trailer indicator lights failing will cause the indicators to flash rapidly like when a bulb goes on the car, thus satisfying the legal requirement.
    Is this correct?
    Does this satisfy the legal requirements?
    Should there be a light on the dash to let you know a trailer is connected?
    I have also read that the cars rear fog should be disabled when a trailer is connected. Is that correct?
    Is there anything else that should happen when the trailer is connected?
    All the lights themselves work ok, but I want to make sure that everything is working as it should.
    Kenny
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    With the genuine VX towing electrics there should be a picture of a green towbar flashing with the indicators. Also if you have bulb failure warning then the system will check the trailer bulbs for faults.
    I believe that the fog light disable along with reverse light disable is an option selectable via tech 2. Plugging in a trailer should also disable factory fit parking sensors (where fitted) and the estates electric tailgate
    Oct 2007
    Shropshire
    You need some sort of tell tail for the indicators legally. Normally this is a buzzer in the back of the car.
    On a facelift vectra you do not get the symbol on the dash...
  1. Trailer tell tail light?
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2011, 12:45
  2. Should I have a trailer light....
    By lds1973 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2010, 20:29
  3. o/s indicator on instead of o/s side light
    By jrr in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2009, 15:07
  4. Exterior Light Indicator
    By paulhb in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2009, 22:01
