Results 1 to 3 of 3
Thread: Noise when Turning Ign Key
    Darlington
    Default Noise when Turning Ign Key
    Vectra C Design 2006 1.8 VVT
    Hi bit of weird one really
    Sometimes, (not all the time) when turning the ignition key to engage the starter motor I can her two ratchetey click noises (thatís the best way I can describe it) that seem to come from the key area (I am not turning the key (i dont think!) at this time) - the car starter motor turns, and the car starts and runs fine, and it generally does it when its really cold morning.
    It does not do it all the time ,and can go for weeks before it happens again.
    Can anyone shed any light on what is happening?
    Many Thanks
    Full Member paul.sessions's Avatar
    leighton buzzard
    sounds like relays
    Darlington
    Where abouts are these relays located?, as it sounds like its coming from inside the car.
    Does this indicate that a relay is on its way out? and will prevent me from starting the car
    Is it easy to replace said relay?
  1. grinding noise turning right
    By jon ixi in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2015, 12:08
  2. squealing noise when turning right.......
    By jinkie in forum Suspension, Wheels & Brakes
    Last Post: 5th October 2012, 20:38
  3. Crunching Noise when Turning
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2010, 18:46
  4. Metallic noise when turning
    By Dwabo in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2008, 19:56
  5. Clicking noise only when turning ignition
    By mbonnick in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2007, 07:10
