Results 1 to 3 of 3
Thread: Clutch Problem
    Jul 2010
    lancs
    Angry Clutch Problem
    Hi,
    Driving to work today and lost clutch. Pedel dropped to floor and hydrolic fluid everywhere. Had to get towed home.
    Not taken to garage yet.
    What sort of work needs doing to fix it? Is it going to be expensive.
    lincolnshire
    you dont say what car you have but i'm guessing its one with the slave cylinder inside the bell housing !? its a gearbox off to rectify so repair will vary on where you take it ?
    Chelmsford
    where is the leak? rear of the engine? or half way forward on the right hand side?
    if it's at the back, it's probably a knackered master cylinder. if it's on the passenger side, it's most likely the slave cylinder as bembo has said. fingers crossed for you that it's the former...
  1. Clutch problem
    By shayom in forum Engine & Drivetrain
    Last Post: 10th May 2012, 23:34
  2. clutch problem please help
    By v33tra in forum Engine & Drivetrain
    Last Post: 12th November 2011, 02:09
  3. Clutch problem!
    By kel123 in forum Engine & Drivetrain
    Last Post: 5th October 2011, 16:07
  4. clutch problem?
    By darko2301 in forum Engine & Drivetrain
    Last Post: 10th April 2009, 21:33
  5. Clutch Problem
    By Aimee in forum Engine & Drivetrain
    Last Post: 30th August 2006, 23:31
