Thread: Seized brake repairs?
    Regular Member bigdave1701's Avatar
    York
    Default Seized brake repairs?
    When I replaced the discs and pads on my 2.2dti sri the rubber boots on the rear brake pistons were quite badly perished & the pistons seized. They took a bit of work to retract but I put a small spot of lithium grease on and gently worked them free again. I wasn't expecting this so didn't have replacement boots, so cleaned out the crud from the old ones and refitted them and until now they've been fine. Last night I got home from the in-laws (30 miles away) and the back discs were red hot leading me to assume they've seized again!
    Is it likely to just be a case of free up the pistons again, grease up and fit some new rubber boots or will it be a bigger job than that? A quick search found a mention of a caliper servicing kit, is this what I'll need to do the job?
    Regular Member Craig1985's Avatar
    harwich essex
    Probably easier and cheaper to get replacements from a spares or breakers yard
    York
    Isn't that overkill?
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Buy a pair of these http://cgi.ebay.co.uk/Brake-Caliper-...item3a60a92f44
    Problem solved
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    get new slider rubbers clean up caliper copper grease slider bolts jobs a good un
    York
    Quote Originally Posted by markj23 View Post
    Is there an easy way of finding the part numbers for the rubbers or will the stealer understand what I'm after if I try and explain?
    Aug 2010
    Luton
    they must be a common request
    York
    Ill give em a bell at lunch time and see if I can order a pair.
  1. Seized brakes.
    By Kaz in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2013, 17:35
  2. WOW!!! Dad in law bought seized vec c
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 18:49
  3. trackrod end seized on
    By david106 in forum Suspension, Wheels & Brakes
    Last Post: 15th September 2012, 18:19
  4. seized caliper ?
    By conny in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2011, 21:28
  5. Rear Brake caliper seized?
    By Ian T in forum Suspension, Wheels & Brakes
    Last Post: 30th December 2007, 11:49
