Thread: Eibachs and a 3.2V6
    Essex
    Default Eibachs and a 3.2V6
    What Eibachs have the V6 PETROL owners fitted?
    Reason i ask is because they do a set with front axel weight up to 1130kg and a set from 1131kg upwards.
    Both are listed as being for the 3.2 petrol.
    Apparently my Signum has a front axel weight of 1135kg, so with B6's do i go for the set up to 1130kg that i assume will be slightly 'softer' as they are will be on the max load, or do i get the 1131kg and up with a slightly 'stiffer' ride?
    With the 'stiffer' B6 damper i'm thinking the upto 1130kg may be the better day to day springs
    Or is that all balls and it makes no difference whatsoever, just buy the cheaper one??
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Don't know if it helps (i know they are not Eibachs) but my PI 45mm are listed as for diesel models as well as the 3.2.
    Lowers the car nicely even on standard shocks.
    EDIT: Just noticed that you said Signum, i've got a GSi Veccie.
    Last edited by Hyperhart; 31st January 2011 at 09:44. Reason: Me being stupid and not reading properly.
    Nov 2009
    Norfolk
    I have Eibachs on my Siggy 3.2 v6
    I had the same questions as you and ended up emailing Eibach and LMF.
    Both came up with the same, heres a copy of what I got in the end including part numbers....
    10-65-011-03-22 Eibach Pro-Kit - Signum and Vectra C Estate Options: Weight Option: Front 1131 to 1230kg, rear up to 1215kg
    Hope this helps!
    From memory all the kits were the same price at the time! Total: £159.60 including postage.
    Nov 2009
    Norfolk
    thanks for all the info?
    the person who started this thread must be too ****in' lazy to reply.
    Essex
    would you like a ladder to help you off that high horse??
    lincolnshire
    the estate and signum have the same eibach kit ! the saloon and hatch i different !
    Nov 2009
    Norfolk
    Quote Originally Posted by stoneshed View Post
    My point was people come on here and give advice, but you cant be assed to reply.
  1. gsi and eibachs.......
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 22:10
  2. BSR, K&N, airbox mod & eibachs.......what next
    By Paul_O in forum Diesel Engine related
    Last Post: 14th March 2010, 19:28
  3. eibachs......
    Last Post: 30th August 2009, 22:36
  4. lowered on eibachs
    By vanquis1979 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2009, 06:21
  5. Eibachs
    By lizard in forum Handling & Braking
    Last Post: 14th August 2008, 08:23
